When I try to play UT2004, the system often crashes to a black screen, and everything locks up,usually during the loading screen.
-Always happens when I try to play Assault, even before the opening sequence.
-Frequently happens in other gametypes (CTF/OS/DD etc) too.
Just now, it crashed to a BSOD with a message (see link). This is the first time, I have got even a warning and BSOD. Usually, the monitor just goes black, and shuts off, and i have to manually reboot.
Screenshot
Text
The crash has occured a couple of times with other games too, but most frequently with UT2004.
I tried a clean install with only XP Pro + SP1 + Mobo Drivers + DX9c + vidcard drivers + UT2004, and no other cards except the vidcard on the Mobo, and the same thing keeps happening.
System specs
Asus A7N266VM-SE
XP 2000+
2x256MB (Kingston + Hyundai)
Gainward FX5700 128MB w/DVI+TV-out
40 GB Samsung HDD
Samsung CRT Monitor 753s running 1024x768@85Hz
Powersupply is FSP Aurora, 350W.
VIA USB2.0 card
Netgear FA311 NIC
XP Pro + SP2
Nforce 5.10 drivers for the Mobo
71.89 for the FX5700
Nothing is overclocked.
Please see Dxdiag.txt for all the details.
Any help in resolving the problem would be greatly appreciated. Thanks!
DXDIAG.TXT
System Information
Time of this report: 5/8/2005, 20:11:36
Machine name: CPU1705
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: Award Medallion BIOS v6.0
Processor: AMD Athlon(TM) XP 2000+, MMX, 3DNow, ~1.7GHz
Memory: 512MB RAM
Page File: 193MB used, 1008MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5700
Manufacturer: NVIDIA
Chip type: GeForce FX 5700
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0342&SUBSYS_040610B0&REV_A1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: SyncMaster 703(M)s/ 753(M)s/750(M)s/753(M)v, MagicSyncMaster CM173A(M)
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7189 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/1/2005 16:16:00, 3980288 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 4/1/2005 16:16:00, 3454656 bytes
Device Identifier: {D7B71E3E-4002-11CF-156F-0C2400C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0342
SubSys ID: 0x040610B0
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: NVIDIA(R) nForce(TM) Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: NFORCE_VAD
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvapu.sys
Driver Version: 6.14.0442.0030 (English)
WHQL Logo'd: n/a
Date and Size: 5/25/2004 15:58:04, 396032 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: NVIDIA(R) Kernel Synthesizer, Hardware (Kernel Mode), Output, DLS, Internal, Default Port
NVIDIA(R) nForce(TM) Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
NVIDIA(R) DLS Synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft Internet Keyboard Pro Hot Keys
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x002B
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x01C2
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 17:30:00, 4736 bytes
+-+ General Purpose USB Hub
| | Vendor/Product ID: 0x0451, 0x1446
| | Matching Device ID: usb\vid_0451&pid_1446
| | Service: usbhub
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC012
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 23:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 23:08:18, 24960 bytes
| | Driver: hid.dll, 8/4/2004 00:56:44, 20992 bytes
| | Driver: hidusb.sys, 8/23/2001 17:30:00, 9600 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
| | | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
Gameport Devices
+ PCI standard ISA bridge
| Matching Device ID: pci\cc_0601
| Service: isapnp
| Driver: isapnp.sys, 8/23/2001 17:30:00, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
PS/2 Devices
+ Microsoft USB Internet Keyboard Pro
| Matching Device ID: hid\vid_045e&pid_002b&mi_00
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection 4 - IPv4 -
DirectPlay8 TCP/IP Service Provider: BSNL DATAONE - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 9.5 GB
Total Space: 38.2 GB
File System: NTFS
Model: SAMSUNG SP0411N
Drive: D:
Model: LITE-ON DVDRW LDW-411S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
System Devices
Name: VIA USB Enhanced Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_12340925&REV_51\4&11D7AD53&0&4240
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:44, 7168 bytes
Name: VIA Rev 5 or later USB Universal Host Companion Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_50\4&11D7AD53&0&4140
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_50\4&11D7AD53&0&4040
Name: NVIDIA GeForce FX 5700
Device ID: PCI\VEN_10DE&DEV_0342&SUBSYS_040610B0&REV_A1\4&29CF4C2A&1&00F0
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 3454656 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0016 (English), 4/1/2005 16:16:00, 32256 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0016 (English), 4/1/2005 16:16:00, 32256 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 3980288 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.7189 (), 4/1/2005 16:16:00, 540672 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 5332992 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 5562368 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.7189 (English), 4/1/2005 16:16:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10040 (English), 4/1/2005 16:16:00, 286720 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 4/1/2005 16:16:00, 165039 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 4/1/2005 16:16:00, 55444 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_01C2&SUBSYS_0C1110DE&REV_C3\3&61AAA01&0&18
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_01C2&SUBSYS_0C1110DE&REV_C3\3&61AAA01&0&10
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_01BC&SUBSYS_0C1110DE&REV_C3\3&61AAA01&0&48
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 17:30:00, 3328 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_01B8&SUBSYS_00000000&REV_C2\3&61AAA01&0&40
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: NVIDIA nForce AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01B7&SUBSYS_00000000&REV_B2\3&61AAA01&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0436 (English), 4/2/2004 15:40:00, 21760 bytes
Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 4/2/2004 15:40:00, 32256 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_01B4&SUBSYS_0C1110DE&REV_C1\3&61AAA01&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_01B2&SUBSYS_00000000&REV_C3\3&61AAA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 17:30:00, 35840 bytes
Name: NVIDIA(R) nForce(TM) Audio Codec Interface
Device ID: PCI\VEN_10DE&DEV_01B1&SUBSYS_83841043&REV_C2\3&61AAA01&0&30
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\nvax.sys, 6.14.0442.0030 (English), 5/25/2004 15:58:02, 48640 bytes
Driver: C:\WINDOWS\system32\drivers\nvarm.sys, 6.14.0442.0030 (English), 5/25/2004 15:58:02, 66688 bytes
Driver: C:\WINDOWS\system32\drivers\nvmcp.sys, 6.14.0442.0030 (English), 5/25/2004 15:58:04, 962560 bytes
Driver: C:\WINDOWS\system32\drivers\nvapu.sys, 6.14.0442.0030 (English), 5/25/2004 15:58:04, 396032 bytes
Driver: C:\WINDOWS\system32\nvack.dll, 6.14.0442.0030 (English), 5/25/2004 15:58:08, 7168 bytes
Driver: C:\WINDOWS\system32\nvasio.dll, 6.14.0442.0030 (English), 5/25/2004 15:58:08, 30208 bytes
Driver: C:\WINDOWS\system32\nvopenal.dll, 6.14.0442.0030 (English), 5/25/2004 15:58:06, 53760 bytes
Driver: C:\WINDOWS\system32\OpenAL32.dll, 6.14.0442.0030 (English), 5/25/2004 15:58:00, 21504 bytes
Driver: C:\WINDOWS\system32\ALut.dll, 6.14.0442.0030 (English), 5/25/2004 15:58:00, 5120 bytes
Driver: C:\WINDOWS\system32\NVCOAD.DLL, 1.00.0000.0015 (English), 5/20/2004 10:11:34, 32256 bytes
Name: NVIDIA(R) nForce(TM) MCP Audio Processing Unit
Device ID: PCI\VEN_10DE&DEV_01B0&SUBSYS_0C111043&REV_C2\3&61AAA01&0&28
Name: NVIDIA nForce 220/230/415/420/430 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01AD&SUBSYS_0C1110DE&REV_B2\3&61AAA01&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01AC&SUBSYS_0C1110DE&REV_B2\3&61AAA01&0&01
Driver: n/a
Name: NVIDIA nForce 220/230 Memory Controller (DDR)
Device ID: PCI\VEN_10DE&DEV_01AA&SUBSYS_0C1110DE&REV_B2\3&61AAA01&0&03
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_01A4&SUBSYS_00000000&REV_B2\3&61AAA01&0&00
Driver: n/a
Name: NETGEAR FA311 Fast Ethernet Adapter
Device ID: PCI\VEN_100B&DEV_0020&SUBSYS_F3111385&REV_00\4&11D7AD53&0&3840
Driver: C:\WINDOWS\system32\DRIVERS\FA312nd5.sys, 5.00.0119.0000 (English), 8/17/2001 12:12:32, 16074 bytes
Name: D347PRT SCSI Controller
Device ID: PCI\D347PRT\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 17:30:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 17:30:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 17:30:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 17:30:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 17:30:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 00:56:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 00:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 00:56:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,Divxdec.ax,5.00.0005.0830
Sonic Scaler,0x00200000,1,1,SonicDSScaler.ax,1.00.0000.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1031
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,netlinka.ax,4.01.0000.3854
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
MainConcept MPEG Encoder,0x00200000,2,1,mcesmpeg.ax,1.00.0001.0014
MainConcept MPEG Video Encoder,0x00200000,1,1,mcevmpeg.ax,1.00.0000.0007
MainConcept MPEG Audio Encoder,0x00200000,1,1,mceampeg.ax,1.00.0000.0003
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1028
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
RTStreamSink,0x00200000,1,0,RTStreamSink.ax,1.00.0000.0000
Ligos MPEG Audio Decoder,0x03680001,1,1,lmpgad.ax,4.00.0000.0083
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,argent.ax,3.00.0000.3433
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1031
Ligos GoMotion Analog to MPEG Filter,0x00200000,2,0,GoMotionAnalogToMPEG1_1.ax,1.00.0000.0005
Arcsoft LPCM Decoder,0x00600000,1,1,lpcmdec.ax,1.00.0000.0000
Sonic RT Stream Source Filter,0x00400000,0,1,SonicRTStreamSource.ax,1.03.0000.0001
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic DVD LPCM Converter,0x00700001,1,1,DVDLPCMConverter.ax,1.00.0000.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ArcSoft Mpeg Writer,0x00200000,2,0,MPEGWriter.ax,2.00.0000.0005
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
File Dump,0x00200000,1,0,filedump.ax,1.00.0000.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Ligos Virtual Source (Version 1.7),0x00200000,0,1,VirtSrc.ax,1.07.0012.0014
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,netlinkv.ax,4.01.0000.3854
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1029
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1031
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
Sonic Audio Offset Filter,0x00200000,1,1,Offset.ax,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Ligos GoMotion DV to MPEG Filter (Version 1.7),0x00200000,2,0,GoMotionDVtoMPEG.ax,
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Sonic Rainbow Fix,0x00200000,1,1,SonicRainbowFix.ax,1.00.0000.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Sonic File Writer,0x00200000,1,0,SonicFileWriter.ax,
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Ligos MPEG Splitter,0x00800000,1,2,lmpgspl.ax,4.00.0000.0083
Ligos MPEG Video Decoder,0x00800000,1,1,lmpgvd.ax,4.00.0000.0083
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic SP Video Renderer,0x00200000,1,0,snicspvr.ax,8.00.0000.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Ligos DV Intercept (Version 1.7),0x00200000,1,1,DvIntcpt.ax,1.07.0012.0028
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
ArcSoft Mpeg Writer,0x00200000,0,0,MPEGWriter.ax,2.00.0000.0005
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
Ligos GoMotion Analog to MPEG Filter,0x00200000,0,0,GoMotionAnalogToMPEG1_1.ax,1.00.0000.0005
Ligos GoMotion DV to MPEG Filter (Version 1.7),0x00200000,0,0,GoMotionDVtoMPEG.ax,
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
NVIDIA(R) nForce(TM) Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
NVIDIA(R) DLS Synthesizer,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
NVIDIA(R) nForce(TM) Audio,0x00200000,5,5,,5.03.2600.2180
WDM Streaming Rendering Devices:
NVIDIA(R) DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
NVIDIA(R) Kernel Synthesizer,0x00200000,1,1,,5.03.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1006
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
NVIDIA(R) Kernel Synthesizer,0x00200000,1,0,,5.03.2600.2180
NVIDIA(R) nForce(TM) Audio,0x00200000,15,6,,5.03.2600.2180
Screenshot
Text
System specs
Asus A7N266VM-SE
XP 2000+
40 GB Samsung HDD
VIA USB2.0 card
Netgear FA311 NIC
XP Pro + SP2
DXDIAG.TXT
System Information
System Model: n/a
Memory: 512MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: n/a
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0342
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Registry: OK
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
| | Service: usbhub
| | Service: HidUsb
| | | Service: mouhid
Gameport Devices
| Service: isapnp
| | Service: gameenum
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 9.5 GB
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
