PC comes on and weird noised from PSU once plugged in - new power supply
Discussion in 'Power Supplies' started by matrophy, Dec 24, 2012.
  1. matrophy
    matrophy Junior Member
    Dec 24, 2012
    I replaced the power supply in my Dell PC with an aftermarket one (Athena brand) of higher wattage and once I installed it and connected everything, without pushing the on button, as soon as I plugged in the AC cord, the power light on the on button came on and horrendous noises which sounded like the hard drive clicking and whirring started right away. It could have been the PSU fan making the noise but it sounded more like a hard drive but real fast whirring and real loud clicking. I immediately unplugged the AC cord and reinstalled my old power supply. The PC started up normally and I had to push the on button to get it to start up.
    I bench tested the new power supply by plugging it into an AC outlet and the blue light on the back came on but nothing else happened. I was under the impression that the PSU fan would come on in this case but it did not.
    Does this point to a bad power supply or something in my installation? I am tempted to return the new PSU but I am reluctant to buy another one if it could have been an installation problem.
  2. Loading...
    Similar Threads - weird noised plugged Forum Date
    Seasonic X-1250 psu weird switch on problem Power Supplies Dec 17, 2016
    XFX TS 550 - weird clicking noise, not the fan, Power Supplies Jun 23, 2015
    Weird problem - maybe PSU dying? Power Supplies Dec 9, 2014
    Corsair CX 430 V2 weird noise. Power Supplies Nov 30, 2011
    Could my PSU be overworked? Weird noise coming from PC Power Supplies Oct 21, 2007
  3. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    Could be some serious capacitor or coil whine.
    Why'd you go buy an Athena PSU, and exactly what model did you buy? Athena aren't good quality; whether it was faulty or not, I would return it and buy a real PSU.
    #2 lehtv, Dec 24, 2012
  4. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    35,642
    534
    Is this an older Dell that used a proprietary ATX connection? That could be the problem.
  5. GAO
    GAO Member
    Dec 10, 2009
    95
    To answer your other question, power supplies won't start up, including the fan, unless plugged into a motherboard or power tester. This is because the Motherboard shorts two pins making a connection signaling the PSU it can turn on. So that is expected and doesn't mean it is dead.
  6. ehume
    ehume Golden Member
    Nov 6, 2009
    1,070
    It sounds like you have an older Dell with their proprietary PSU connections. Be grateful you didn't kill something.
    Next time do some homework:
    1. Find out what pin assignments your exact Dell uses. You ought to be able to find it on Wikipedia or a more general web search.
    2. Do your homework on PSU's. Athena has an ugly rep. Take it back and don't buy another until you know what brands are reputable.
    But in the end, you may have no other choice than to stick with what you have, or buy another Dell. One thing about Dell: they buy really good PSU's, often with Delta and San Ace fans in them. Why? They don't want the PSU to die so they must replace it.
    I've had Dells die on me, but I always just replaced the rig: they were generally old by the time they died. Most were retired, though.
  7. matrophy
    Dec 24, 2012
    I could use a suggestion on what you would consider to be a good brand of PSU's.
  8. matrophy
    Dec 24, 2012
    Once I know the pin assignments that my current Dell PSU uses, I'm not sure what to do with that info. Is that what I use to find a compatible aftermarket PSU?
  9. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    Antec, Corsair, PC Power & Cooling, Seasonic, XFX. There are decent units from other brands as well including Cooler Master, Thermaltake, Silverstone, Kingwin, OCZ etc. but you can't go wrong with the first ones.
    For the budget oriented, Corsair CX series is a sure bet. Midrange: Antec Neo Eco, Antec Earthwatts, Antec HCG, Corsair TX, PC Power & Cooling MK III, most Seasonics, XFX everything. High end: Antec HCP, Corsair HX, Corsair AX, Seasonic X series.
    You can also get a decent idea of what's what by browsing PSU reviews conducted by JonnyGuru and Hardwaresecrets.
    #8 lehtv, Dec 25, 2012
  10. Eureka
    Eureka Diamond Member
    Sep 6, 2005
    3,828
    You must tell us what the older model of PSU was. Some Dell PSUs were custom made for them, so they have different pin-outs. For those PSU/Motherboards, you cannot just replace it with any other power supply.
    Why did you replace your PSU at all? Was it failing?
  11. bryanl
    bryanl Golden Member
    Oct 15, 2006
    1,135
    Dell abandoned that connection over a decade ago. Those Dell motherboards had a second power connector, a single row of 12 flat pins for ground and +3.3V lines. Power supplies for such motherboards will have a pair of 6 pin connectors to match. Connecting a standard ATX power supply to such a motherboard will short every voltage line to ground.
