PC CHIPS M825LU V7.2C WITH CPU AMD ATLON Pro3000A+ help
cmelodysax
Ok heres the problem. I have a geforce 2 64mb dual monitor video card that i want to use with this motherboard. The problem is that I cannot find a way to disable the onboard video. I looked all the through the bios and nothing was there. I cant even find the jumper that controls it because theres not even decent enuff diagram in the manual. Now I dont believe that a motherboard that has onboard video and a AGP slot has no way to disable the onboard video. This is starting to drive me nuts. Im searching over the internet for more information about the motherboard and I have found nothing. The bios dates from 2/2/04, which is last month for all of you without a calendar. I need help!!
Peter
9,640
The trick is that you don't have to. If you plug an AGP card and do so successfully, the integrated VGA automatically vanishes. If you add a PCI card, it stays there for multiscreen use.
Most people who don't get it disabled simply failed to push the AGP card in all the way.
