I have pretty much narrowed down the components for my new system, but am getting stuck on what case to use. I'll list the components, but basically the few questions I have are:
1) Is there any advantage to a TOWER as opposed to MID TOWER, if a Mid Tower provides al the expansion room you will ever require? (Is a Tower Cooler because it's larger)?
2) Is the additional cost for an Aluminum case worth the expense? I realize they are nice looking and light, but do they really provide that much more of a cooling environment then a regular case?
My Components:
OS Win XP Pro
Asus P4T533-C
P4-2.4B
512 Corsaire 1066 Rdram
WD 1200JB 120GB 8MB Buffer HD
Teac 1.44 Floppy
Toshiba 16/48 DVD-ROM
Plextor 40/12/40 CD-RW
Asus GF4 Ti-4600 Ultra Deluxe
SB Audigy Plat.
Promise Ultra 133 IDE (so CD drives can be on seperate controllers)
Antec True 430 Wat
Cases being considered:
Coolermaster ATC 101 Aluminum Full Tower $250ish
Lian Li - 70 Aluminum Full Tower $209ish
In Win Full Tower Non-Alum $70ish
I'm really stuck on what the heck to do about a case. This system is costing a lot as it is and while I'm willing to get the appropriate case, I don't want to spend anymore at this point then I feel it reasonable too.
Thank you,
Terrapin
My Components:
OS Win XP Pro
Asus P4T533-C
P4-2.4B
Teac 1.44 Floppy
SB Audigy Plat.
Antec True 430 Wat
Thank you,
Terrapin
