pc case km84 mercury,case fans help
meganin
151
hi i am having this http://www.mercury-pc.com/images/pr_ca/KM/pr_casing_km8 pc case
for now i using it open case thers no case fans at all,i want to close it with proper case fans cooling the motherboard chips , as when i touched the southbrigde its 1 second touch hottterrr,than northbridge,mine is refurbished asus p5ql pro,very old system e2180 cpu for now,2 gb ram ,gt730 ddr5 zotac garphics,planing to buy xeon modded cpu 5450 with good aftermarket cpu cooler later,but before i want to put case fans to cool the mobo,pls give som suggetion,thanks
BonzaiDuck
16,709
2,081
20 years ago, I might have sneered at the idea of corrupting my PC enthusiasm with sheet-metal work. In my youth, I attended a parochial prep school and there were no metal-shop classes.
About 15 years ago, I started doing sheet-metal and other mods on old cases. My greatest project in 2007 involved a Compaq ProLiant 1995 "full-plus" tower case. I wish I still had it. I gave it to a sibling on a whim of impatience for handing down the electronic innards.
Right offhand, I'd say the case shown in your link needs more air intake with less restrictions, but there isn't a picture of the case interior, so I don't know what the existing unmodded potential might be.
But the first thing I myself might do follows this set of steps and parts.
First, I'd cut a hole in the case bottom to fit one or more 120 or 140mm fans (maximum of two fans), and drill the holes for the fan mounts. I would then obtain a piece of perf-steel from a metal shop or from online PC case-modding stores, with dimensions overlapping the exposed fan ports, and I'd pop-rivet the perf-steel to the case bottom before finishing the holes for the fan mounts and adding the fans.
For the fans themselves, I'd steer you toward some Corsair Mag Lev ML120 or ML140 fans (PWM-control) -- the LED option is your choice. Or -- consider the Bitfenix Spectre Pro 140mm LED fans with 3-pin voltage control. Also, for PWM choices, consider the Noctua iPPC 2000 or 3000 models of 140mm, or investigate other Noctua choices of 120 and 140mm.
It is important that you can have motherboard control of any of these fans, because some can be noisier than others. Use rubber or silicon fan mounts wherever you can. You can also mount the fans with cable ties, nylon machine screws and nuts, or anything that offers a possibility of inserting rubber tape or Spire acoustic foam-pad material in the construction to isolate the fan from metal.
SECOND -- (bet you wondered when we'd get to this or anything else) -- buy some braked 2"-to-2.5" double-caster wheels with the 4-screw square mounting plates, use a $10 Sears screw-tapping kit to drill and thread four holes in the case corners, and you now have ventilation from the elevated bottom in addition to mobility for the case.
The caster wheels can be obtained from:
Lawless Hardware in Olney, Illinois
The set of four should cost you less than $20, or they will be something in that range.
If you don't have a rear exhaust fan -- and it will likely require a 120mm x 25mm unit -- consider one of the Noctua fans. I'd prefer one with high throughput, between 70 and 100 CFM.
But you should be able to thermally control all of these fans from the motherboard, unless you pick some add-on fan controller that allows for thermal control from the CPU heat-sensors.
meganin
151
wow,this is so much overhead for me,but i dont have the guts and time for that,but will sure this imprint of idea will be ther,thanks
aigomorla
21,087
3,593
oh dear... this picture scares me the most...
i am seeing your PSU completely open and naked, which can spell a lot of problems since if your PSU shorts out, it can take out your entire system.
Also looking at the case, it seems like you dont have many fan options.
Are you a experienced system builder?
Do you know how to rebuild your system inside a different case?
At this point i would highly recommend just paying a bit more, and replacing the case entirely into a new shell.
You can probably get a decient case for cheap.,
However i also highly recommend you replacing that PSU more so then anything, as i would never run a PSU naked like that.
BonzaiDuck
16,709
2,081
I think Aigomorla says it all . . . and I agree -- better to invest in a new case. And take care of that power supply. Like Aigo says -- replace it . . . .
meganin
151
actully for takin pics i turned the pc this way,as this side would be litle closer to wall (not too much close),i will close the power supply soon with its cover(the fan was producing too much sound,so picked it out for som time),thinking about making holes in side panel to fix fans in it!! thanks for your suggestions friends...
for a new case--- cant do it any sooner as i want to buy som other parts like cpu ,cooler for cpu n som fans to cool down motherboard(dont hav any idea how to fix the fans to blow on the motherborad anyway),after all this done,,then i have to see a cheap model for pc case...pls don mistake me i am not listening to you,..tight budget here hehe..btw planning to buy e5450 cpu xeon modded,v6 cooler , som 120 mm fans ,and also tell if its neccesary to cool down harddisk ,its 40 now ...in summer my room temp will be 29-30 for a month may be...have to really cool down bridges vrm mofsets watever they are...sory for a long post..jus afraid tats all...i do no overcloking.
for now my temps of components are within 35-40 in load(jus internet and cs1.6),jus southbridge is too hot to touch 2 secs mostly
