pc build help
Discussion in 'General Hardware' started by adamc012, Nov 3, 2012.
  1. adamc012
    adamc012 Junior Member
    Nov 3, 2012
    Hi guys,
    need some advice on my first pc build. im looking to build a cheap gaming pc for around $550 AUD, nothing too fancy just something that can run new games at medium to high settings with playable fps.
    Buying parts From MSY in Australia, have no intentions of overclocking either.
    I've come up with two builds so far
    Build 1
    CPU: Intel core i3 2120 - $119
    Motherboard : MSI H61M-P20(G3) H61 1155 2xDDR3 DVI mATX* - $42
    RAM: G.Skill-NT 8GB Kit (4Gx2) DDR3 1333 ram - $35
    GPU: Gigabyte GV-N650OC-1GI 1GB GTX650 - $130 or Gigabyte GV-R777OC-1GD 1GB HD7770 - $119
    HDD: Seagate 3.5" Barracuda 500GB ST500DM002 SATA3 7200RPM - $60
    Case: *Antec 200V2 Two-Hundred-V2 Gaming Tower Case without PSU - $49
    PSU: Antec Neo Eco 520C 520W PSU - $79
    Optical Drive: Samsung SATA 22x Black DVD RW - $19
    Network Card: TP-LINK TL-WN781N PCI-E 150M*Wireless-N 150M Network Card - $13
    Total $545/$534
    Build 2
    CPU: Intel Pentium G850 2.9Ghz - $79
    GPU: Powercolor 1GB 7850 PCI-E VGA Card - $179
    Total $550
    Which Build would you consider better for my needs and any advice or suggestions would be appreciated
  2. Loading...
    Similar Threads - build Forum Date
    Build Advice for a Portable Video Recorder PC General Hardware Saturday at 5:31 PM
    Upgrading PC parts help General Hardware Sep 18, 2017
    Upgrading to the 8700k after 7 years. Advice on this build please. $2,000+ General Hardware Sep 15, 2017
    New i7-7700 build General Hardware Sep 11, 2017
    nephew grad present: RGB build ($2K) General Hardware Sep 9, 2017
  3. riversend
    riversend Senior member
    Dec 31, 2009
    477
    Do you need a copy of Windows?
    Do you have any parts from another system that you can reuse?
    What games are you thinking?
    What is your monitor resolution?
  4. adamc012
    Nov 3, 2012
    Dont need windows
    No parts to reuse
    games like borderlands 2, fifa 13 but not on maximum ultra settings
    1920x1080 res
  5. lambchops511
    lambchops511 Senior member
    Apr 12, 2005
    659
    Do you really need that optical drive? FYI. You can install Windows off an USB drive (which I have been doing for several years now).
  6. Ken g6
    Ken g6 Programming Moderator, Elite Member
    Moderator
    Dec 11, 1999
    12,909
    409
    Well, let's see. The difference between putting an i3 in the second build and not is $40. I found MSY's parts list (PDF) here. So, if you drop to the Antec Neo Eco 450, that saves $21. If you can ditch the optical drive as well, that's the entire $40 you need to get the second build with an i3.
  7. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    As it stands, the second build is better because the GPU is the #1 most important part of a gaming PC. You can definitely get them both if you can drop the ODD and/or wireless adapter.
    If you spend $50 more, you can also get a decent boost with an Ivy Bridge CPU (~15% clock for clock) and a 2GB GPU. The 2GB of VRAM is especially important at 1080p as many games are already exceeding 1GB.
    i3 3220 $123
    ASRock B75M-DGS $60
    G.Skill DDR3 1333 8GB $35
    PowerColor 7850 2GB $199
    Seagate 500GB $60
    Samsung DVD Burner $19
    Antec VP450 $52
    Cooler Master Elite 334U $40
    TP-Link 802.11n card $13
