PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Burning music,video's,watching movies,lite video editing,General pc use.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread 550.00 U.S.
3. What country YOU will be buying YOUR parts from. USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.Intel..
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.Wd 1tb black drive,Kb,Mouse,Monitor,Speakers,Windows 7 64 bit os
6. IF YOU have searched and/or read similar threads.Yes several..
7. IF YOU plan on overclocking or run the system at default speeds.Default but may oc in the future if possible in my budget.
8. What resolution YOU plan on gaming with.1920x1800
9. WHEN do you plan to build it?Now
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Hello forum.I have a 550.00 dollar budget i answered the sticky above as you can see i need a cpu,psu,memory,mobo,case and would like a 7750 gpu if at all possible,i know it's stretching it.. I already have a hd and a copy of windows 7 64 bit.I would like this pc to last a long while as this one is between 5 to 6 years old.
Intel e6400 core 2 duo.
3gb gskill ddr2 800
Nvidia 7900gs
antec true power 600 w psu
new addition before hd's sky rocketed that will be used in new build Wd black 1tb hd.
Many thanks
3gb gskill ddr2 800
Nvidia 7900gs
Many thanks
