PC Build Help and Recomendations
Discussion in 'Computer Help' started by Demonic Angel, Jan 7, 2013.
  1. Demonic Angel
    Demonic Angel Junior Member
    Jan 7, 2013
    Hello,
    My Username is Demonic Angel and I am new to this forums, my purpose to be writing this thread is to get recommendations and help from you experts on my Build. I would also Appreciate it if you guys told me if the stuff would fit in the case ,how much "watts" I need for the computer to work and if everything is compatible with each other.
    Here is my shopping list for the build so far.
    http://www.newegg.com/Product/Produc...82E16811156062
    http://www.newegg.com/Product/Produc...82E16822136533
    http://www.newegg.com/Product/Produc...82E16814500272
    http://www.newegg.com/Product/Produc...82E16800999298
    http://www.newegg.com/Product/Produc...82E16820145345
    http://www.newegg.com/Product/Produc...82E16813131790
    http://www.newegg.com/Product/Produc...82E16819116782
    total: 711.94
    Cheers, Demonic Angel.
  2. Loading...
    Similar Threads - Build Recomendations Forum Date
    New Ryzen build stability issues Computer Help May 16, 2017
    New build, cpu voltage issue Computer Help May 14, 2017
    Can/Should I still upgrade or a new build would be better? Computer Help May 13, 2017
    New build won't post Computer Help May 11, 2017
    Would like recomendation on gaming laptop just for CoD Computer Help Jun 13, 2013
  3. Demonic Angel
    Jan 7, 2013
  4. denis280
    denis280 Diamond Member
    Jan 16, 2011
    3,409
    Welcome to the forum.We could help you but it would be better to move your post to · General Hardware
  5. Smoove910
    Smoove910 Golden Member
    Aug 2, 2006
    1,188
    I would definitely get rid of the Raidmax case/powersupply combo (you'll thank me later)
    The zotac v-card is suspect too since I don't really like that brandname... I'd also try for something with a 256-bit memory bus instead of 128-bit
    I'm not an Nvidia guy, but this looks like a decent deal for a little more $$ (has a $30 mail in rebate which sweetens the deal) Plus, it seems like a better vcard overall.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446
    http://www.hwcompare.com/13473/geforce-gtx-560-vs-geforce-gtx-650/
    #4 Smoove910, Jan 7, 2013
  6. leej1982
    leej1982 Junior Member
    Jan 7, 2013
    4
    personally i would have gone with a full tower atx gamers case, but it should fit, but be warned the nvidia graphics cards gt x series are rather large so ensure the case is big enough before you buy...but everything seems compatible and should work nicely
