Question PC build for a Data Crunching and VR Gaming upgradable PC Build within $500-600
amitbb
Greetings,
I want to build a PC build that is possible for future upgrades(next few months). I’ve detailed my current situation and future plans below.
**1. Purpose:** My primary focus is on data crunching and AI/ML development, alongside high-end VR gaming experiences. The system should be capable of handling intensive computational tasks with the flexibility to upgrade components for enhanced performance in the near future. GPU/CPU/RAM etc for this can be upgraded in future if required.
**2. Budget:** $500. Also open to second-hand parts if it means better initial value or performance. Additionally, I plan to invest an extra $500-1000 in the coming months for upgrades, focusing on a build that supports upgradibility.
**3. Location:** Mumbai, India. I've identified several vendors known for competitive pricing and reliability:
- Amazon India: [amazon.in](http://amazon.in)
- Prime ABGB: [primeabgb.com](https://www.primeabgb.com)
- Elite Hubs: [elitehubs.com](https://elitehubs.com)
- Game Loot: [gameloot.in](https://gameloot.in)
**4. Brand Preference:** None except your recommendations
**5. Current Parts:** This will be a fresh build, starting from scratch without the reuse of any existing components.
**6. Overclocking:** Yes, I intend to overclock with a view to future component upgrades.
**7. Resolution:** My current setup operates at WFHD resolution, but I aim to transition to 4K.
**8. Build Timeline:** The assembly is planned within the next few weeks, recognizing that prices and availability are subject to change.
**9. Software Needs:** No additional software purchases are required for this build.
**Additional Details:**
- **Upgradability:** Withing one year, planning to upgrade but much sooner actually —selecting a case, motherboard, and PSU that facilitate easy upgrades. The goal is to accommodate a high-end GPU and potentially other high-performance components in the year ahead.
- **Upgrade Motivation:**: to enhance my capacity for data analytics and AI/ML project work, and to elevate my VR gaming experience.
- **Peripherals:** keyboard, mouse, monitor, Bluetooth/WiFi receiver) and will not need replacements.
I look forward to your recommendations on how to best approach this build, particularly in making initial selections that align with my upgrade aspirations.
Thank you in advance!
manly
13,439
4,157
Welcome to the forums.
Based on your description, you need to save up money until you're ready to buy a good ML system.
Right now you have enough for the GPU, and nothing else. $600 gets you a 4070 Super. I'm not certain 12GB VRAM is considered "enough" but Nvidia is far superior than AMD for these workloads. I would never plan to upgrade parts in 10-12 months time. You're almost certain to lose money that way, although what you gain is a lower end system for today.
Reactions: VirtualLarry
