I am planning to replace my old Inspiron 6000 laptop with a custom-built budget system. This will be my first build, ever, so I'd like some advice.
Note the Micro-ATX form factor--I'd like to make this system relatively unobtrusive if possible.
Where should I cut? Or is an SSD so essential that I should go ahead and get one for $100 more, or should that be saved for a future upgrade? Have I forgotten anything? Should I break down and just buy a pre-built system?
Okay, here is my initial build:1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
- Multimedia:
- Photo storage/editing with Photoshop
- Home video storage/light editing
- Streaming video
- Possible Blu-Ray playing (I have no TV)
- Compute:
- Complex Excel work with Solver
- Statistical Analysis using R
- Light database manipulation (Tableau, possibly Access)
- Gaming:
- No heavy 3D gaming
- Europa Universalis/Magna Mundi compute-intensive gaming.
3. What country YOU will be buying YOUR parts from.
- $750ish for the entire package, including monitor, OS, keyboard, etc.
- One of the main reasons I am posting here is to try to peg the best place for me on the value/performance curve.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
- United States (Maine)
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
- No Preference
6. IF YOU have searched and/or read similar threads.
- I have no parts
7. IF YOU plan on overclocking or run the system at default speeds.
- Yes. One recent, sort of similar build is at http://forums.anandtech.com/showthread.php?t=2229905
8. What resolution YOU plan on gaming with.
- Probably default speeds
9. WHEN do you plan to build it?
- 1920x1080, but again, no complex 3D gaming.
- Within the next month or 2 (should I wait for anything?)
$135 - Intel Core i3-2105 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 3000 BX80623I32105
$105 - GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$50 - G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR2
$90 - Antec NSK 4482 Black / Silver 0.8mm cold rolled steel ATX Mid Tower Computer Case 380W Power Supply
$100 - Seagate Barracuda Green ST1500DL003 1.5TB 5900 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$18 - LG 22X Super-Multi DVD Burner Black SATA Model GH22NS90B - OEM
$30 - Rosewill RNX-N250PCe (RNWD-11005) PCI Express 150/300Mbps 2T2R Wireless Adapter
$100 - Microsoft Windows 7 Home Premium SP1 64-bit - OEM
$240 - Dell UltraSharpTM U2312HM 23" Monitor with LED
TOTAL: $868, plus shipping
Obviously, that is a little more than my preferred budget, and that is without even talking about an SSD boot disk, a Blu-Ray player, or a (probably unnecessary) graphics card.$105 - GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
