PC build advice.
burgers
24
Hey all,
Am new here, have been reading the forums, this one mainly, for the last few weeks and decided it was time to make a post and get some advice. I'm a Uni student in the UK so have quite a tight budget.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General work, Internet surfing and gaming, but not that intensive.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
£300-£350
$600-700
3. What country YOU will be buying YOUR parts from.
The UK
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Not really, but was planning to go with Intel, but open to suggestions.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Basic Keyboard and mouse
Planning to nick a 17" tft sceen from home.
Hopefully a CD-RW drive from an old dell Optiplex...?
vista premium 32bit
6. IF YOU have searched and/or read similar threads.
Yea have done quite a bit of research and reading other build threads.
7. IF YOU plan on overclocking or run the system at default speeds.
No not really, don't know how etc.
8. WHEN do you plan to build it?
Within a month really.
Have used www.scan.co.uk for the pricing and includes VAT
This is what I'm looking at at the moment:
Case: Coolermaster RC-330 V2 Elite Black Midi Tower Case - £24.66 = $49.14
PSU: 500w Seasonic S12II-500 PSU - £52.75 = $105.13
Mobo: Gigabyte GA-P35-DS3L - £56.75 = $113.10
CPU: Intel Core 2 Duo E8200 - £113.96 = $227.11
Heat sink: planing to use the retail one and upgrade later to a Freezer 7 Pro.
RAM: 2GB (2x1GB) Corsair TwinX XMS2 PC2-6400 - £30.13 = $60.05
GPU: 512MB Palit/XVision 8600GT - £45.23 = $90.14
HDD: 500 GB Samsung Spinpoint T166 - £46.99 = $93.65
PSU: Would prefer to buy a cheaper one (£20=$40 EZcool) but from what I have read it isn't clever?
CPU: Have been reading today about the E8300 which seems to be the same price as the E8200 so am guessing I will go with that.
RAM: I know that I really need 3 or 4 GB but I was planning to put another 2 sticks in end of next month.
GPU: Would like a better one but cant see how I can afford it.
Total : £370.47 = $738.32
So slightly over budget, but I guess thats what my overdraft is for :D
So any help on the matter would be very appreciated.
Roguestar
6,045
Good to be recommending parts in £s again. Don't hit that overdraft unless you have to, it'll come in handy later! Besides, we're not due another student loan installment until next year :(.
Change that CPU for an E2200 and overclock that bad boy to 3GHz, spend some of the cash saved on the freezer pro. £40 saved.
http://scan.co.uk/Products/Pro...sp?WebProductID=778009
It's only £55 for 4GB of DDR2-800, get that:
http://www.scan.co.uk/Products...sp?WebProductID=632574
Consider getting the 9600GT rather than the 8600GT if you'll be doing a bit of gaming. Not the best card out there, but definitely good and definitely better than the 8600.
burgers
24
Thanks for the reply.
How difficult is it to overclock? Would I be able to learn from reading up on it on the net for example? And how does the 1MB cache effect performance compared to the 6MB offered by the E8200, and the lower FSB speed? Basicly would I be getting a better/similar performance from it after I overclock it?
Yea good point might go with the extra RAM.
Looking at this ANTEC case with PSU as well, works out at the same price and the case seems quite a bit better.
Thanks
Tom
Roguestar
6,045
Overclocking it so, so easy. When I was trying to overclock my E6300 I read up on it for a few weeks during coming up with my list of parts (also ordered off scan!) and then decided to give it a go once I'd got the whole thing up and running. I started really carefully but after a while I realised I could just slap the FSB to 401MHz and let it fly. The Core 2 CPUs are generally really easy to overclock. Just browse through the CPU & Overclocking subforum for a bit reading up on it.
burgers
24
Ok thanks for the help.
Think I will go with this build then:
Case: Antec Conata III With 500W PSU - £78.60 = $155.82
Mobo: Gigabyte GA-P35-DS3L - £56.75 = $112.50
CPU: Intel Dual Core E2200 - £49.93 = $98.98
Heat sink: Arctic Cooling Freezer 7 Pro - £14.38 = $28.51
RAM: 4GB (2x2GB) Corsair TwinX XMS2 PC2-6400 - £55.21 = $109.45
GPU: 512MB Palit/XVision 8600GT - £45.23 = $89.66
HDD: 500 GB Samsung Spinpoint T166 - £44.50 = $88.22
Total = £344.60 = $683.14
Will put the order in first thing Monday morning.
Thanks again for your help Roguestar.
Edit: Have just read the HEXUS review for the case and they mention that the PSU doesnt have dedicated rails for overclocking. Am I going to need dedicated rails if I plan to OC the E2200?
