Hi,
I've a pc with the following configuration:
Motherboeard: Gigabyte X48-DQ6
RAM: 2X2GB ddr2 G.Skill
CPU: Intel Q9550
VGA: Nvidia 9800GTX+
PSU: Enermax modu +82 625W.
From one day to another the pc started to reset at the boot without I made any change, both in software or in hardware.
The reset that makes the loop is after the bios but before the loading of any bootloader.
Considering that I have no problems to access to the bios configuration where everything looks ok, but i can't start any test like memtest 'cause the reset, indeed, it happens in the next step after bios but before the boot check.
To find/fix this I tryed the following:
-start pc with all periphery removed (including hd, cd-roms etc..);
-remove motherboard battery and resetting cmos;
-start pc also without rams;
-start pc with another vga;
but problem in all cases persist.
What I can highlight is that during all the time the V_PHASED leds of the motherboard stay all time light up in all three colors (red, orange and green.
As I remember well, when the pc worked good, the V_Phased led, after boot, the lights went out.
I believe that my motherboard is broken but I've the doubt that also something other can be damage.
The strange thing is that from the bios everythings looks ok!!!
CPU: Intel Q9550
