I run optical out from my computer to my receiver and it works fine. You just have to be aware that you will only get stereo sound over optical unless you have a DDL/DTS Connect sound card or are watching a source that's already Dolby encoded.
Thanks all I had two older receivers that lost there HDMI ports during a lightning strike.
Turns out that I can't get the Optical to work either.
I will just have to wait till I have the cash to buy another receiver.
I have two extra speakers and I just figured I would use them. They should sound better than my $20 Logitech speakers.
