PC-70 / PC-75 window door
Yourfriend
8
I've been trying to find this item for about a week searching the Net but no luck. Anyone know where in the U.S. I could get this?
Since the PC-75 window door fits the PC-70 it doesen't matter if it says "PC-75". I'm sure some know this.
Thanks for any suggestions you may have.
mandrake88
78
have you tried pcmods.com, i think they have it.
how are these cases?? i am expecting a delivery of the pc-71 today and hope it is
a good case.
Neuroanatomist
I think I once saw a PC-75 window at so-trickcomputers.com
..but it looks like it was limited stock as they don't currently list it.
(another example of something they had, but no longer list, is that Lian Li aluminum floppy drive cover)
Looks like he has Lian Li spare parts. Might want to email the guy there to see if he can get you one.
Yourfriend
8
<< have you tried pcmods.com, i think they have it. >>
I've emailed pcmods.com but there seems to be some communication difficulties:
>> >Hello,
>> >In the next order I'm going to need some miscellaneous items along with
>> >one or two PC-70 side panels, rheobus etc. Do you have or would you be
>> >able to get the window panel for the PC-70? If yes what would be your
>> >price. From what I understand the PC-75 window panel also fits the
>> >PC-70.
>> >Thank you,
>pcmods wrote:
>> We have the PC70 left door and the rheobus will be avaliable on the 15th.
>> Thanks,
>> Chirsty
>By "left door" do you mean the door without the window?
>Thanks.
The door far from the motherboard.
Thanks,
Christy
<< how are these cases?? i am expecting a delivery of the pc-71 today and hope it is
a good case.
It's a great case. As far as design critiques I would say if the doors where a little more easier/faster to take on and off it would be an improvement (thinking of G4 door design).
Stronger CFM fans in the front intake would also be welcome for those who do fully utilize the capacity of the drive cage on the bottom front inside.
Bear in mind this is like asking for perfection if you were to compare the PC-70/71/75 to most other cases. IMO overall it is superior to most cases.
<< I think I once saw a PC-75 window at so-trickcomputers.com
I emailed so-trick 2 days ago and still no reply.
That's why I decided to post, looking for alternatives.
