Pathfinder starting problem, ideas welcome
Status
Not open for further replies.
Princeman
My 1993 3.0L Pathfinder, initially starts right up. Turn it off and it will click only and sometimes starting after 10-15 minutes. I have replaced the starter, battery, battery cables, and ignition switch. The alternator tested good, but I am thinking of getting a fresh one too. It had a factory alarm system and later I had a Viper installed. Viper checked it a while ago and said it wasn't the alarm keeping it from starting. I replaced the ignition switch and that fixed my starting problems back then. There's a starter relay that often goes bad on this Nissan, but I got a new one of those too. It's what clicks when you turn the key now. Alternator and battery dashboard warning lights go out when running. Runs well and recently passed emissions. I put the battery on a slow charge after running it down trying to get it started. Usually can fix stuff by myself but running out of ideas. Getting stuck somewhere happens a lot. Thanks
Check the starter solenoid signal cable with a multimeter. That should be 12V when you have the key turned to the start position and 0V at any other position.
Status
