patching servers remotely problem
HydroSqueegee
1,709
I have a script that installs updates on remote servers. It has worked well with 2003, but fails on Server 2008. The error in the setup log says "Windows update could not be installed because of error 2147942405 "Access is Denied." Command line: wusa c:\temp\windows6.1-KB....
The VBS is run from my PC through an admin command prompt.
If I run the exact same command while logged into the server (with the same admin account), it works fine. The script copies the update to the remote server, installs and deletes the file. I've tried to lower the security settings on the server, but that didn't help.
Is there a setting you can change to allow updates to be installed remotely?
Code:
Connecting to SERVERNAME...
6.1.7600
Copying installation file
Process created.
Command line: WUSA c:\temp\Windows6.1-KB2562937-x64.msu /quiet /norestart
Process ID: 5116
[B]No proccesses with ID 5116 are running[/B]
Installation successful.
Deleting file
Done!
the "No proccesses with ID 5116 are running" line is how i know it failed and the setup log will show access denied. the install is not successful.
seepy83
2,132
Sounds like a UAC/Privilege Escalation problem.
I haven't had a need to script installs on remote servers like this, and I haven't used a WUSA command line, so that's about the best info I can give you. Can you specify RunAs Administrator to get your privileges escalated?
HydroSqueegee
1,709
i thought it was a UAC problem too. i killed all the UAC options in secpol i could find, but the problem persists. the comand line on my local PC is RusAs Administrator with my admin account that has admin rights on the servers. Ive been looking at trying to put something in the script that specifically launches the Win32 process with admin credentials, but im no programmer, so progress is slow.
seepy83
2,132
Do you mind posting the vbs that you're using? There's lots of programmers and sys admins here that have scripting experience.
Nothinman
30,672
The first question would be why aren't you using tools made just for this like WSUS and Windows Update?
HydroSqueegee
1,709
because this is the government and nothing can be that easy. We cant use windows update and WSUS is controlled by another team and its easier for us to just use a script than deal with them.
the WSUS guys only push down patches mandated from one source, the main source for all patches here. However there is another source that deems other patches need to be installed as well for security reasons. these sources do not talk or interact with eachother but we have to report compliance to both...
see my problem here...
HydroSqueegee
1,709
sho nuff.
Code:
on error resume Next
const W2k3_Patch = "WindowsServer2003.WindowsXP-KB2562937-x64-ENU.exe"
const W2k8_Patch = "Windows6.1-KB2562937-x64.msu"
const LocalPatch = "c:\temp\"
Dim strcommand
If right(ucase(wscript.FullName),11)="WSCRIPT.EXE" Then
    wscript.echo "ERROR: You must run this script using cscript, for example 'cscript " & wscript.scriptname & "'."
    wscript.quit 0
end If
' ipFile = wscript.arguments(0)
ipFile = "C:\Temp\comps.txt"
set ofs = createobject("scripting.filesystemobject")
' Verify that ipfile is accessible.
set oipFile = ofs.opentextfile(ipFile, 1, false)
	if (Err.Number <> 0) Then
    wscript.echo "Cannot open " & ipFile
    wscript.quit
	end If
' Make sure to end with a \ character.
if right(LocalPatch, 1) <> "\" Then
    LocalPatch = LocalPatch & "\"
end If
'Note that cim_datafile does not support UNC paths 'so everything must be handled through mapped drives.
if left(LocalPatch, 2) = "\\" Then
    wscript.echo "<pathToExecutable> cannot be a UNC path, please map a drive locally"
    wscript.quit
end If
exeW2k8 = ofs.getfile(LocalPatch + W2k8_Patch).name
exeW2k3 = ofs.getfile(LocalPatch + W2k3_Patch).name
' Verify that the patches are accessible.
if ((len(exeW2k8) = 0) OR (len(exeW2k3) = 0)) Then
    wscript.echo "Cannot find patch files."
    wscript.echo "Please verify that the <LocalPatch> folder contains all of these files:" & vbCrLf & "      " & W2k8_Patch & vbCrLf & "      " & W2k3_Patch
    wscript.quit
end If
set osvcLocal = getobject("winmgmts:root\cimv2")
'The error-handling code is below the function that may throw one - execute it.
' on error resume next
while not oipFile.atEndOfStream
    ip = oipFile.ReadLine()
    wscript.echo vbCrLf & "Connecting to " & ip & "..."
    Err.Clear
    set osvcRemote = GetObject("winmgmts:\\" & ip & "\root\cimv2")
        wscript.echo "Failed to connect to " & ip & "."
    Else
        exeCorrectPatch = detectOSPatch(osvcRemote)
        If (exeCorrectPatch <> "") Then
            WScript.Echo "Copying installation file"
            Ret = ofs.CopyFile(LocalPatch & exeCorrectPatch, "\\" & ip &"\C$\Temp\", True)
            if (ret <> 0 and ret <> 10) Then
                ' Failure detected and failure was not "file already exists."
                wscript.echo "Failed copy to " & ip & " - error: " & ret
				WScript.Sleep 5000
            Else
                strComputer = ip
                Set objWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
                ' Create The patch installation process
                Set objProcess = objWMIService.Get("Win32_Process")
                intReturn = objProcess.Create(strCommand, "c:\temp", Null, intProcessID)
                If intReturn <> 0 Then
                    Wscript.Echo "Process could not be created." & vbNewLine & "Command line: " & strCommand & vbNewLine & "Return value: " & intReturn
					wscript.quit
                Else
                    Wscript.Echo "Process created." & vbNewLine & "Command line: " & strCommand & vbNewLine & "Process ID: " & intProcessID
                    Do
                        WScript.Sleep 5000
                        blnCheckProcess = CheckProcess(intProcessID)
                    Loop While blnCheckProcess = False
                End If
                wscript.echo "Installation successful."
                WScript.Echo
                WScript.Echo "Deleting file"
                Ret = ofs.DeleteFile("\\" & ip & "\C$\Temp\" & exeCorrectPatch, True)
           end if     'Create process succeeded.
        end if     'Copy succeeded.
        'onet.removenetworkdrive "z:", true
    end if      ' The script knows which patch to install.
    'end if
' Do the next IP address, then the next IP address...
Wend
oipFile.close()
WScript.Echo vbCrLf & "Done!" & vbCrLf
Function detectOSPatch(osvcRemote)
    set oOSInfo = osvcRemote.InstancesOf("Win32_OperatingSystem")
    'Only one instance is ever returned (the currently active OS), even though the following is a foreach.
    for each objOperatingSystem in oOSInfo
        WScript.Echo objoperatingsystem.version
        if (objOperatingSystem.OSType <> 18) Then
            ' Make sure that this computer is Windows NT-based.
            wscript.echo ip & " is not a Windows XP, Windows 2000, or Windows 2003 Server computer."
        Else
            if (objOperatingSystem.Version = "5.2.3790") Then
                ' Windows Server 2003.
                if (objOperatingSystem.ServicePackMajorVersion = 0) or (objOperatingSystem.ServicePackMajorVersion = 2) Or (objOperatingSystem.ServicePackMajorVersion = 3) then
                    strCommand = "c:\temp\" & exeW2k3 & " /quiet /norestart"
                    systemType = exeW2k3
                end If
            ElseIf (objOperatingSystem.Version = "6.1.7600") or (objOperatingSystem.Version = "6.1.7601") Then
                ' Windows 2008R2.
                if (objOperatingSystem.ServicePackMajorVersion = 0) or (objOperatingSystem.ServicePackMajorVersion = 1) then
                    strcommand = "WUSA c:\temp\" & exeW2k8 & " /quiet /norestart"
                    systemType = exeW2k8
                end If
            end If
            if (systemType = "") Then
                'This was a Windows NT-based computer, but not with a valid service pack.
                wscript.echo "Could not patch " & ip & " - unhandled OS version: " & objOperatingSystem.Caption & " SP" & objOperatingSystem.ServicePackMajorVersion & "("& objOperatingSystem.Version & ")"
            end If
          end If
     Next
     detectOSPatch = systemType
end Function
Function CheckProcess(P_intProcessID)
    Set colProcesses = objWMIService.ExecQuery("SELECT * FROM Win32_Process WHERE ProcessID = '" & P_intProcessID & "' ")
    If colProcesses.Count = 0 Then
        WScript.Echo "No proccesses with ID " & P_intProcessID & " are running"
        CheckProcess = True
    Else
        For Each objProcess in colProcesses
            WScript.Echo objProcess.ProcessID & ": " & objProcess.CommandLine
        Next
    End If
End Function 'CheckProcess
' Win32_Process.Create Return Codes
' Value Description
'   0   Successful Completion'
'   2   Access Denied
'   3   Insufficient Privilege
'   8   Unknown failure
'   9   Path Not Found
'   21  Invalid Parameter
FSfromTX
I have a very similar script and have the exact same problem. I've been really banging my head against the Windows 2008 (and Windows 7) wall. I hope someone knows the answer.
rasczak
10,437
22
Could you request the WSUS guys approve the patches you require to comply with both sources?
imagoon
5,199
A local administrator:cmd runs in the computer accounts level. Do a run as using a domain admins account to launch the cmd.exe and run the script that way.
FSfromTX
Hi All,
I appreciate all those who are offering assistance.
I'm running the script as a domain admin on my local machine, and I suspect Hydrosqueegee is as well. So the remotely executed patch is launched with those same credentials. Since we're running the patches on remote computers, using the runas can be problematic, as you can't interact with the command once you've launched it. Also, other commands work, it just seems WUSA is locked down more.
dphantom
4,763
327
Windows 2008/Win 7 handle remote access/administration differently than previous OS's. Powershell is now the recommended method. You may also try to set the "allow remote administration exception" group policy under gpedit.msc | computer configuration\administrative templates\network\network connections\standard profile\windows firewall, and set the appropriate IP range
FSfromTX
hi dphantom (and all),
Unfortunately, that didn't help. I still get "access denied" and error code 2147942405.
