Patch cable from DSL modem to NIC
bbseim
26
I am trying to make a custom 25' cable to run from my Fujitsu/Orckit Speedpath DSL modem to my NIC and have run into some issues.. mainly that I can't get it to work! The ONLY cable that seems to work is the one that came w/ the modem, which the manual indicates is a crossover cable. SO I have crimped/recrimped about 5 times to no avail. In my research (and on some other sites) I have come to the conclusion that
1 White/Green 1 White/Orange
2 Green 2 Orange
3 White/Orange 3 White/Green
4 Blue 4 Blue
5 White/Blue 5 White/Blue
6 Orange 6 Green
7 White/Brown 7 White/Brown
8 Brown 8 Brown
should be the correct way to make the cable. And as such is the way I have been trying. I feel confident in my ability to make a freaking cable (made all my own for my lan save for the crossover from Fujitsu for the modem) so I believe it is more in the way the premade cable is wired. Anyone else had this situation? Am I crazy, do I have bad info? Their manual indicates it's a crossover cable.. I am unable to see the wires inside the jack to determine the order of their wiring.. I am planning to procure a meter to test continuity on the cable, but it was an unused molded cable I cut the ends off of, so I'm pretty confident that the cable itself is ok.. Any thoughts/suggestions appreciated.. Bob
fourtwenty
888
4
Why don't you test the cable that came with it for continuity, that would easily tell you how the cabels are set up.
bbseim
26
Damn 420, you'd think I've been drinkin or something... great idea! Will try.. thanks a million.. will advise.. out..:eek:
