Password help
note235
I dont remember the password to a linksys rtp 300 router,. I changed it.
Is there a program that decrypts passwords over browsers or can i call them or can i reset the password?
You can reset the router.
It should have a small 'pin hole area' that you stick a pin in to for about 5-10seconds. This resets the router to it's default Login and P/W.
Enter and change the details to something you can remember 🙂
Koing
