- Nov 22, 2012
- 19
- 0
- 0
This topic is pursuant to this thread, where shortly after I posted asking about my GPU being defective, it answered the question for me by failing completely.
Anyway, what I want is to replace my GPU with another midrange model, more powerful than my previous GTS 450, and I want to passively cool it. I know my case can handle a passively cooled GTS 450 (106W TDP), so I want to stay around this level of power consumption.
I've narrowed my GPU search down to these:
AMD :
Radeon R7 260x (115W, $140)
Radeon HD 7790 (85W, $130)
NVIDIA:
GeForce GTX 650 Ti (110W, $125)
Expected use patterns are CAD (Pro/Engineer) and light gaming (Starcraft II, Kerbal Space Program, at 1920x1200). I will be driving a second monitor, but won't typically be using both for 3D work.
My questions for those knowledgeable about GPUs:
What's the difference in performance between the R7 260x and the 7790? I read the Anandtech article, and it seems like they use the same chip. Is there a performance or feature advantage to the newer card, or am I better off buying the older one?
How do these stack up compared to the GTX 650 Ti in my expected use patterns?
Is there a new release in this price segment (in the next couple months) that I should be waiting for?
What's a good, solid, reliable brand? I will almost certainly want a reference layout, and it would be a bonus if replacing the cooler didn't void the warranty.
My choices for passive cooling are as follows:
-Reuse the cooler that came with the GTS 450. It's free and I know it copes relatively well with this TDP. I may have to modify it to fit, but I have the skills to do that (would rather not take the time though) and if I screw it up, I'm not out any money. Disadvantage: it's a direct-touch heatpipe design, and only 2 of the 4 heatpipes rest on the GPU die, and there's a fair gap between them. This may be partly why the GTS 450 failed (there was a small area on the die that had no TIM on it when I took it apart). If I reuse it, I'd probably want to add a copper heatspreader, either soldering it to the heatsink (will be a smidge tricky, because it's a pretty effective heatsink--also because I don't know if those heatpipes will burst at soldering temperatures) or just adding another layer of TIM. It also gives me the problem that the assorted VRM and RAM heatsinks may not be compatible with the new card, so I'm probably looking at $10 to $15 in thermal tape/epoxy and new VRM heatsinks.
-Arctic Accelero S1 Plus ($40)
This is a relatively lower-cost cooler, but for one, it doesn't look too different from what I have in the cooler that came off the GTS 450. I haven't determined that it's off-the-shelf compatible with any of the cards I'm looking at. The link to the manufacturer's website comes up 404, which is not encouraging... Also, reviews seem to suggest that I'll need to provide my own thermal adhesive and maybe some extra VRM/RAM heatsinks, so that's another $10 or so to the cost.
-Prolimatech MK-13 ($60)
This is a more expensive option, but I think it'll be a higher-quality cooler. It doesn't seem to list any modern cards for compatibility, though. Does anyone know if this fits any of the cards I'm considering? It's also a little worrisome that the manufacturer doesn't actually suggest running it without a fan. It's about the same size as the GTS 450 cooler, though it looks to be higher quality...
-Prolimatech MK-26 ($75)
I'm confident this cooler will have the performance I need, but the price is steeper than I wanted to pay. It lists plenty of modern cards as compatible, but the 7790 is notably not listed. Does anyone know if a stock 7790 board is the same as a stock 7770 board (which is listed), or is it different? (Also, it's out of stock there, and doesn't seem to be sold in very many places, so I may have some trouble actually buying one.)
Is there anyone out there that has done the passive-GPU thing and has some feedback for me? I've had quite a bit of trouble even tracking these down, so maybe I've missed something.
Thanks for any replies.
AMD :
NVIDIA:
