Passive cooling for Intel core 2 duo
I0s
61
I have a E6300 and currently have the supplied intel's s hsf on it and find it kinda loud. I was hoping if there is a passive cooling hsf for my chip.
It is housed in a Sonata II, if that helps.
Thanks
Puffnstuff
16,187
4,871
Are you sure it's the hsf that you're hearing? While I was running the stock hsf the fan was silent even at max speed. If you want silent then you need one of the larger hsf with a slow and silent fan.
I0s
61
I am not 100% if it is from stock hsf, but just wondering about my alternatives. The only other fan is the PSU fan that cames with sonata, the case fan is set to low so it quiet.
btw, the e6300 is not oced and will not be.
mgutz
123
for starters you can undervolt the e6300 to reduce heat. even at a 2.4Ghz OC i was able to undervolt the 6300. download orthos utility to test. get a heatsink with loose spacing between fins. they work best with low RPM fans or passive. the scythe ninja is a good choice (ultra 120?). mate the heatsink with a silent fan at low RPM. put the fan on the heatsink in a pull configuration, pulling air towards the exhaust fan. get rid of the exhaust fan on the case. the fan on the heatsink will act both as a cpu cooling fan and exhaust. putting it in a push configuration cools better but the air flow might not be strong enough to exhaust. the idea is to get rid of one fan yet still actively cool the fins. if you are fine with the sound of tri-cool exhaust on low speed use that on your heatsink to save $. i use yate loons. their quality vary, at $3.50 each buy three and pick the best one.
i had my Antec Solo in this configuration with suspended drives, a Corsair 520HX psu. this psu has 12cm fan on bottom so it also helped exhaust. you literally had to concentrate to hear it. check out silentpcreview.com if you want to get serious about silence
one more thing, the noisiest components are usually the VGA cooler and chipset fans. Gigabyte makes great passively cooled 7600 GT cards.
Binky
4
I run an E6400 @ 3.2ghz with a passive Ninja in a Sonata I (single rear case fan, carboard semi-shroud). Idle temps are around 45C and heavy gaming can bring it up to 60C. It works perfectly. If it gets warm, I just kick up the speed of the rear case fan.
