passing %COMPUTERNAME% in SQL Connection string?
Homerboy
30,890
5,001
Provider=SQLOLEDB.1;Persist Security Info=True;User ID=XXXXX;Initial Catalog=CLS;Data Source=SQL;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID=%COMPUTERNAME%;Use Encryption for Data=False;Tag with column collation when possible=False
I have the above connection string to connect to SQL.
However, when it connects the "Workstation ID=" literally shows up as "%COMPUTERNAME%" and not the actual name of the computer calling the connection string.
Is there anyway to get the system variable to dynamically pull in the string?
ForumMaster
7,792
i don't think you'll be able to do like this. %COMPUTERNAME% is an environment variable.
perhaps you can do this:
"Provider=SQLOLEDB.1;Persist Security Info=True;User ID=XXXXX;Initial Catalog=CLS;Data Source=SQL;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID="+
System.Environment.GetEnvironmentVariable("COMPUTERNAME", EnvironmentVariableTarget.Machine)+
";Use Encryption for Data=False;Tag with column collation when possible=False"
if that doesn't work, call the function first into a variable, then concatenate the variable is a similar fashion. otherwise you'll get a literal "%COMPUTERNAME%" instead of the value.
link
Homerboy
30,890
5,001
what you pasted didn't work, but I'm reading the link now and trying to make heads or tails of it.
KLin
30,951
1,079
What programming language are we talking about?
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
It depends on the programming language. the connection string is exactly that, a string. Whatever string builder you are using needs to pull the computer name and insert it into the string.
KIAman
3,342
23
Why do you need workstation ID in the connection string? Are you actually using the host information in the SQL server? Also user id but no password?
That junk looks like a typical connection string builder output.
