I need some advice for parts to go with a 3930K that will be overclocked. I know, poor timing with the 4930K so close, but I need to build a couple of these machines in the next 2-3 weeks. These will be for use as workstations and render machines for 3D graphics and animation. Both single thread and multi-thread are heavily used, so the 3930K is what I plan to build these around.
Power Supply - I have one Seasonic X750 and will probably get another for the 2nd system.
Heatsink - I have a Noctua NH-D14 SE2011 and plan to get a second for the other system.
Memory - I plan to pick up a 4x8GB kit for each system. I have no idea what would be best. I'm not sure how memory behaves with x79. Needs to fit with the Noctua. I would like to keep the price under $300 or not much over.
Motherboard - I'm really not sure what to get here. Reliability is important. I want to be able to overclock these machines to about 4.6-4.8. Only one GPU will ever be used in these. It would be nice to have 8 memory slots, but I wouldn't exclude boards with only 4. Being able to swap out the CPU for a newer one at some point might be a nice option, although that kind of knowledge may not be available yet. I would also like to keep the price under $300 if possible.
Storage - SSD. I will start with one or two and may get to as high as four at some point. No advice needed here.
GPU - EVGA GTX 760 4GB
Case - Corsair 500r
OS - Windows 8 Pro 64-bit
Thanks
Edit: Added case and graphics card I would like to use.
Case - Corsair 500r
Thanks
