AMD 2500+ Barton
Abit NF7-S
ATI 9600pro
2x 80Gb Western Digital HD (one is SE and the other is reg)
Win XP
Now the problem:
I wanted to start from scratch after installing a DVD burner and new HD so I decided to format all my drives, except 1 partition that I use to backup files. During Windows XP installation the partition drive screen showed up so I formatted the other 3 partitions.
Turns out that somehow I formatted the drive with my data backup files. I have 2x 80Gb drives, each partitioned in half (40GB). So the drives are:
80Gb WD Special Edition = drives C: and D:
80Gb WD non-SE = drives E: and F:
In the Windows installation screen where you can partition drives it shows 2 rows....first row drive C with drive E below it and the second row drive D with drive F below it. From what I understand each drive should be together, as in C with D below it and E with F below it.
So now, my D drive is actually the E drive where I put my backup data because when I formatted drive D the backup data is now gone. I want to fix this problem. My system seems alot slower since the new format.
Should I start from scratch and format both drives, then partition both drives with some 3rd party program once Windows is installed?
Abit NF7-S
ATI 9600pro
Win XP
Now the problem:
