Partition Magic 8 problem
Turbonium
2,154
82
I merged 2 partitions back together using PM8, and it created a folder in the resulting partition containing data I had from the second partition before merging.
Problem is, I can't delete the folder now. It gives me a generic "make sure folder is not write-protected/isn't in use by another program" message.
Anyone know how to work around this? I've tried Googling with no luck.
I tried booting up in safe mode into a Command Prompt, but DOS doesn't even know the folder is there. I go "del foldername" and it says it can't find the file. Within XP, it knows it's there, but as mentioned, refuses to access, modify, or delete it...
theMan
4,386
are you trying to delete the contents of the folder, or just the empty folder?
Turbonium
2,154
82
Well, the curious thing is that the folder is actually empty, as I had no data to save from the second partition. PM8 did not give me an option not to make a folder however.
So all I'm trying to do is delete an empty folder!
corkyg
Elite Member | Peripherals
27,370
239
Right click on it and tell us what the properties say.
Turbonium
2,154
82
It is Read-Only, but it has a horizontal line (dash) through it, it's not actually "selected" with a full fledged checkmark or what not.
I've tried getting rid of it but it always refuses as mentioned before (cannot be modified).
