Part time gamer build
Discussion in 'General Hardware' started by itzyosh, Feb 4, 2013.
  1. itzyosh
    itzyosh Junior Member
    Feb 4, 2013
    15
    After my trip to microcenter (I could get addicted to that place :)) will start the build this weekend probably [​IMG]
    Edit: I noticed No power cable with the psu. Will i need to pick up any other cables?
    #26 itzyosh, Feb 7, 2013
  2. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    Neo Eco doesn't come with a power cable? I thought only Earthwatts had that.
    All other cables should be covered
  3. itzyosh
    Feb 4, 2013
    15
    Nope says so on the box lol. What about for the ssd?
  4. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    What all did you get? The picture is blur-tastic enough that I can't tell. The Z77 Pro3 only comes with 2 SATA cables; you'll obviously need extras if you have more than 2 SATA devices.
    The power cord is a standard NEMA 5-15P to IEC C13 lead, you probably have one laying around the house from some other electronics.
  5. itzyosh
    Feb 4, 2013
    15
    Sorry bout the horrible pic, took it real quick before i left out.
    Z77 Pro 3 + 3570k
    8gigs crucial ballistix low pro
    Seagate 1tb
    Samsung 840 120 gig
    Neo Eco 520
    7850 twin frozr
    corsair 200r
    few odds and ends while at microcenter, Ended up spending about $750 total not much over budget
  6. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    If you also have a dvd drive then you need that additional SATA cable mfenn mentioned
  7. itzyosh
    Feb 4, 2013
    15
    holding off on the optical drive gonna get a blueray drive
  8. Sleepingforest
    Sleepingforest Platinum Member
    Nov 18, 2012
    2,376
    I'm sensing some scope creep. You know Bluray playback requires extra software and the drives are pretty expensive, right?
  9. itzyosh
    Feb 4, 2013
    15
    No scope creep lol... I can get what i need done on the pc without a disk drive for now. Bluray wont be for a couple months. Im done spending now.
  10. mfenn
    Jan 17, 2010
    22,403
    In that case, you only have 2 SATA devices, so the included SATA cables are enough.
