Part 2...monitor won't come out of sleep
Geron
Hi all,
Actually seems like a continuation to the problem just raised...well
I assembled a new system recently with a Winsonic motherboard. The monitor I used was a Sony Trinitron which was transferred from my other computer.
However, after I shut down the system after use and try to switch it on again, the monitor does not seem to come on, still remains in the power saving mode with the yellow light.
It can't be the monitor cos it worked perfectly fine in my old system.
Could anyone help? Would really appreciate it.
Stripe
Try re-seating the video card. I had a similar problem with an IWIll KK266 motherboard. Wound up having to RMA the board. Like the AGP slot was bad, the card just made occasional contact.
Sugadaddy
Banned
May 12, 2000
6,495
There should be a setting in the bios to select what kind of videocard you're using, and it's usually set to PCI by default. I had a similar problem, and selecting AGP fixed it. Try it, it can't hurt... (if you're using an AGP card of course)
eStacy
125
Hey i am having the same problem. after i go to restart my computer starts to boot up but the monitor stays in sleep. im using a ep8k7a . but i havent updated my BIOS but i wasnt sure if that was the problem.
In my BIOS the AGP setting for video card is the default.
