parsing values in SQL w/ delimiter
Homerboy
30,890
5,001
say my return value on a query is "Amount: $100.00" for "SALE_AMT" column.
But I only want the "100.00"
I KNOW there has to be an easy function for this in the query, but for the life of me I can not figure it out.
Homerboy
30,890
5,001
SUBSTRING(ACTIVE.NOTE, CHARINDEX('$', ACTIVE.NOTE) + 1, LEN(ACTIVE.NOTE)) AS Test
what a pain the ass. I can't believe they don't have something like RPARSE(ACTIVE.NOTE.'my choice of characeters>) built in.
Homerboy
30,890
5,001
Substring(sales_amt, 9)
I thought of that, but sadly I left out a bit of info.
"Amount?: $100.00" is a fixed width value.
So when its $100.00 there are 10 spaces between the : and the $. If it's $1000.00 there are 9 spaces...
WannaFly
2,811
Similar to your other thread if it's always "AMOUNT: " then use replace. If you must use 3 replaces, one for "AMOUNT:" one for "$" and one for all spaces.
Homerboy
30,890
5,001
Oh I like that solution too! sneaky.:ninja:
As I get more and more into SQL and more elaborate reports/queries, that is one thing I like about it; there's always a dozen ways to do 1 thing... each better than the next.
Homerboy
30,890
5,001
yeap. I'm familiar with "RIGHT", and have used it on a few occasions.
Thanks.
beginner99
5,320
1,768
Or one could say its retarded to store "Amount?: $100.00". Not your fault but the guy that came up with this idea sure didn't understand what a relational database is.
It's like driving your car into a river and then wonder why it doesn't float.
Excel freaks are a PITA.
ForumMaster
7,792
A better way is this:
substring is a functions that requires as input:
that column
from where to begin
where to end
if you use 3 replaces each time on the column, that's 3 additional function calls.
it adds overhead.
the preferred method is this: using instr (a function that returns the position of a string in another string). it requires as input a column and the string to find.
an example:
substr(active.note,instr(active.note,'$')+1)
that's it. you don't have to provide the third parameter for substr if you want the rest of the string (length of column).
