KarmaPolice
Ok, I am going to try and describe this as best as possible.
My mom owns a very successful jewerly store. She started it herself and has done very well. This being said..she is very computer illiterate...and I am here "Tech Guy". I help with some things here and there but my dad also helps. Recently her computer will only boot into safe mode..and its a very important computer. Everything is backed up so I can reformat it and start over but I am looking for a better system. right now its kind of a mess tech wise.
Here is the layout..
4 computers:
1. The paper work computer(the one that broke down). This is where quickbooks is used and special jewerlly software. All of the files are saved here aswell..
2. Store computer..used for employee email and tracking. Also has the jewerly software but looks to computer 1 for the files
3. Same type as number two pretty much...looks to computer 1 for files
4. is a POS system.
As you might have noticed..because computer 1 went down now none of the computers can use the jewerly software cause the files are not found. What would you suggest to be the best set up for this situation. There are cat5 cables running to a hub, and then to a router I believe.
Would me buying a server be the best way to go? How should I go about doing this? I have never set up a dedicated server for anything and have no knowledge of the windows NT.
Any thoughts are welcome. thx
4 computers:
4. is a POS system.
