Pardon my stupidity... But I have a quick power supply question
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Its been a few years since my last build (I stopped building right before SATA became popular)
I have my dad's old system right now running as a file/orb server. Its an ECS K75SA mobo w/ an Athlon 1600+ cpu and two IDE drives (CDRW & HD).
I've been sick of how noisy the whole thing is, so I went ahead and purchased a new case w/ 120mm fans & am about to order a new power supply (likely the Corsair 550vx as it seems to get rave reviews and is quiet).
This brings me to my question - Do modern power supplies work with older motherboards and components like mine? (with the old fashioned white molex connectors for power)
I plan to upgrade the mobo/cpu shortly, but would like the PS to work on my old components as well in the meantime.
Thanks in advance!
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
They have not changed from using Molex connectors. PSU's still come with plenty of them.
And the 24-pin has 4-pins that break away, so it will work in a motherboard with 20-pin main connectors.
aphex
Moderator
Jul 19, 2001
38,572
Rock on! Thanks!
Is there anything else I should consider for quiet reliable operation? With the GC coupon, the 550vx is $45ar.
aphex
Moderator
Jul 19, 2001
38,572
Actually, the Corsair tx650w is only $52ar for me. Think i might just go for that one instead
aphex
Moderator
Jul 19, 2001
38,572
One last Q if I may, what about the HX520 for $17 more? ($69ar)
Its going in a really small lian-li case, so the less cables the better I suppose.
aphex
Moderator
Jul 19, 2001
38,572
Thanks guys! Decided to go with the modular hx520 to save a bit on the clutter.
Have a nice night!
Lunyone
482
Where did you find that deal? I'd like to know, so I can add it to my b-day list, which is coming soon! :)
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
You mean so you can add it to your copy and paste list of Corsair deals that you use in almost every post. ;)
Lunyone
482
No so I can go and buy one. :)
aphex
Moderator
Jul 19, 2001
38,572
Buy.com, but the rebate ended last night. $24 rebate combined with $20 google checkout discount.
The rebate is still good on the 550vx and hx520
