Well, as it appeared to me, but someone here said otherwise.
Probably me! The early firmware did not, which is why the drive was passed on for that big endurance test. That's been fixed for much longer than I've known that it has been fixed, it appears.
Thing is, I had a trial of SSD Life pro and it expired. So I then got another copy of the free version which does not let me engage SMART.
I just use CrystalDiskInfo, for SMART, on Windows. It stays fairly up to date, and has tables for different custom values on drives. Function -> Advance Feature -> Raw Values sets dec/hex options. Some values are commonly 2/4 or 2/2/2. Temperature, FI, reads as 39 22 31 (highest, lowest, current, deg C), in Dec - 2 byte.
As you can see, it is also very
Japanese. I also notice now it shows total host writes, so I didn't have to go calculating it from host sector writes.
And only 525hrs...way to go, sleep modes!
I am not sure to what extent the predicted lifespan element in SSD Life is valid, if it can be trusted at all
In terms of expected aging, ???.
P.S. I
did make a mistake with the numbers. Yours can't be 329..., and mine 646..., without a difference of about 50% in writes, min.
So, that's 1.83TB written. Assuming:
>3000 p/e NAND
240GB = 223.5GiB
End of life NAND writes = 223.5*3000 = 670500
WAF = 2.47
Actual NAND writes = 2.47*1.83TB = 4629GB
% used = 100*(4629/670500) = 0.69%
So, you've used about 1/140th of the lifetime, if it's rated for 3,000 p/e, if the above numbers don't have anything wrong in them.
