M4H, yes at least one should be, but I think Dell screwed up and put in wrong riser. Then again, even with correct riser, it may still only support 3.3v cards, which are keyed differently than older 5v cards.
Not completely. Some older legacy cards will not operate in a PCI-X system. If it has a notch on the front of the card as well as the back then it is PCI 2.2 complient. Non 2.2 complient cards have one notch to the rear. PCI 3.0 will not have a notch to the rear but will only have one in the front and will be 3.3 volt only.
