Panasonic EDTV and Xbox 360 Resolution?
Thraxen
4,683
I don't think it will hurt anything, but why even set the 360 to an HD resolution if your TV is limited to 480p?
Zolty
3,603
Originally posted by: FFactory0x
Wouldnt a 720p signal downscaled to 480p look better?
I don't understand how it would look better, you have the same amount of pixels, I could be wrong though.
Thraxen
4,683
Hmmm... I'm guessing that your TV is doing the scaling. My gut feeling is that it would not look any better, but I honestly don't have the technical knowledge to answer that with certainty.
funboy6942
15,362
416
When I was looking up projectors that were 480p they claimed feeding hd content into them looked better then the sd signals because it was feeding higher pixals and the pj was downscaling it. Instead of a sd lower pixal input being manupliated to progressive. You fed it a much better picture to begin with to downscale. Keep in mind these were all EDTV Pj's that took in computer res and HDTV res through the componant or dvi inputs.
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
FWIW, my 720p native DLP looks better when I set my cable box to output a 1080i signal vs. a 720p signal.
jpeyton
Moderator
Aug 23, 2003
25,375
142
Originally posted by: dmw16
Wouldnt make a difference. EDTV FTL :(
What kind of TV do you have champ?
