Panasonic DVD player problem
bluerpk
97
Hello guys
I bought a new DVD player..the Panasonic CP 72. I hooked up the player to a DVD player to a Sony Wega using Component cables. It runs interlaced fine but when i try to switch to progressive, it gives a flickering image. After going through the manual, i found out its an issue with the copy guard. Does anyone have any suggestions to make it work.
BTW. I took the DVD player to India. So I cant return it. Any suggestions to make it run in progressive mode would be extremely helpful.
Thanks.
Heisenberg
10,621
Macrovision issue? If so, you can buy boxes that defeat it. Don't know if there are any that support component video though.
bluerpk
97
The strangest thing is that the manual mentions only the progressive output. The interlaced output through the component cables works perfectly.
edog
27
If the answer to GOSHARKS question is yes then it sounds to me like you have the same problem a bunch of people have with this player, which is a grounding problem with the component jacks in the player.
You can Check it out here CP72 Flashing
Muadib
18,120
910
Originally posted by: GOSHARKS
uh - *obvious question* can the sony display 480p in the first place?
I'm betting the answer is no. What model Wega is it, bluerpk?
bluerpk
97
Yes..the WEGA is a digital one..with DRC capability..capable of outputting progressive signals.
Can someone please explain the grounding problem and how i go about fixing it.
Thanks again.
