Originally posted by: Ken90630
Nothing against Panaflo's (I recently bought one myself), but you might want to check out
these fans and also the 92mm fan
here.
Both compare favorably (if not better) spec-wise with Panaflo's, and I think you'll find both are rated to be quieter (although decibel ratings for computer fans are notoriously unreliable). I never read anything but positive comments about all three brands. I can tell you that if noise is a concern, you will definitely hear fans running at 30 or 35 dB like the Panaflo's you mention (unless you're in a noisy room). You need to be around 20 dB or less to reach an "inaudible" or "virtually inaudible" threshold.
FYI, Panaflo's and SilenX fans are only warrantied for one year.
🙁 But then again, I've never heard anyone complain about them failing.
🙂 PC Power & Cooling told me on the phone that the Silencer is warrantied for 3 years.
Just some food for thought, if you're interested.
