Panaflo 80mm on Antec pp-303x PS & PS fan for intake?
Feb 2, 2001
188
Umm...I have the Antec KS-282 case and the pp303x PS that came w/ it. I also use 2 Panaflo 80mm's, one for intake and another for exhaust.
A couple of days ago I also did a half assed case mod. What I did was jimmy a sloppy hole underneath the 80mm exhaust hole w/ a drill. Not a drilling blade [or whatever those are called] but drilled one whole at a time until I had a small circle. Then I took 2 small CoolerMaster fans and glue-gunned them together. Then I glued them to the inside of the case to blow out of my half assed whole. So those 2 fans added a bit of exhaust air flow.
While I had the case taken apart, I also cut out the grills for the intake and exhaust 80mm holes.
So my question now is since as I understand exhaust is more important than intake, should I take the intake Panaflo and throw it in the PS? Then set up the PS fan as my intake case fan? Does this sound like a bad idea or go for it? I think my temps are ever so slightly hot for my setup cause I have a fop38 w/ artic silver on the proc and I run about 36-37c idle. Shouldn't that be closer to about 30-31? Thanx for any help
