Palit GTX285 always running at full load
Vnix
Before this, everything works fine. My card auto goes into 2D mode when idle and into 3D performance when I playing games. After installed some basic program and Vista update. After boot into Vista, the clock speed is always running at 648MHZ even idle. I try to restart comp and still the same and you can't DC or OC it. The only thing you can control is the fan speed. I am running on Vista Ultimate X64 and using the latest driver from Nvidia. Please help and sorry for my ENG. Thanks.
HWM BlackBox 1.02
Saturday, March 07, 2009
11:16:32 AM
CPU # 1
Manufacturer : Intel
Model : Intel Core 2 Duo E8400
Package : Socket 775 LGA
Processor ID : BFEBFBFF0001067A
Version : Model 7, Stepping 10
Revision : E0- 5898
Instructions : MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Codename : Wolfdale
Core : 2
Thread : 1
Technology : 45 nm
Address Width : 64 Bit
Data Width : 64 Bit
Maximum Speed : 3,000.00 MHz
Current Speed : 1,970.76 MHz
Speed (O/C) Rate : % 65.69
Multiplier : 6.0 x
Bus Speed : 328.48 MHz
FSB : 1,313.91 MHz
L1 Code Cache : 2 x 32.00 KB
L1 Data Cache : 2 x 32.00 KB
L2 Cache : 6.00 MB
L3 Cache : -
Physical Memory
Module Count : 2
Empty Slots : 2
Total Size : 4.00 GB
Channels : -
Memory Type : DDR2
Frequency : 394.15 MHz
FSB:DRAM : 5 : 6
Speed (O/C) Rate : % 98.54
CAS Latency : 5.0
RAS - CAS Delay : 5
RAS Precharge : 5
Cycle Time : 18
Bank Cycle Time : -
Command Rate : 2T
Module # 1
Modul Slot : DIMM0
Manufacturer : Kingston
Week / Year : 00 / 00
Part Number : 2G-UDIMM
Serial : -
Memory Type : DDR2
Band Width : PC2-6400
Maximum Speed : 400 MHz
Data Width : 64 Bit
Profil # 1 : 200 MHz - 3.0 - 3 - 3 - 9 - 12 - 1.8 V
Profil # 2 : 266 MHz - 4.0 - 4 - 4 - 12 - 16 - 1.8 V
Profil # 3 : 400 MHz - 5.0 - 5 - 5 - 18 - 24 - 1.8 V
Module # 2
Modul Slot : DIMM2
Serial : -
Memory Type : DDR2
Data Width : 64 Bit
Mainboard
Manufacturer : Asus
Model : P5Q-Pro
North Bridge : Intel P45/P43 A3
South Bridge : Intel 82801JR (ICH10R) 00
PCI-E Slot (x16) : 2
PCI-E Slot (x8) : -
PCI-E Slot (x4) : -
PCI-E Slot (x1) : 2
PCI Slot : 2
AGP Slot : -
BIOS
Manufacturer : American Megatrends Inc.
Version : 1501
Date : 11/04/2008
VGA # 1
Model : NVIDIA GeForce GTX 285
Graphic Memory : 1 GB
Driver : nv_GT2x 7.15.11.8208
Disc # 1
Model : ST380817AS ATA Device
Media Type : 3.42
Firmware : 75 GB
Size : 1 Partition
Partition : IDE
Interface : Fixed Hard Disk Media
Disc # 2
Model : WDC WD2000JS-00MHB0 ATA Device
Media Type : 02.01C03
Firmware : 186 GB
Size : 1 Partition
Partition : IDE
Disc # 3
Model : WDC WD16 00BEVS-22VAT0 USB Device
Media Type : 1A11
Firmware : 149 GB
Size : 2 Partition
Partition : USB
Interface : External Hard Disk Media
Windows
Windows : Microsoft® Windows Vista? Ultimate 64-bit
Version : 6.0.6001 Service Pack 1
Product ID : 89587-OEM-7332132-00031
Performance
System Rate : 5.8
Processor Rate : 5.7
Memory Rate : 5.9
Graphics Rate : 5.9
Video Encoding Rate : 5.9
3D / Game Rate : 5.9
Hard Disc Rate : 5.2
Processor Performance
Compression Type 1 : 156.40 MB/s
Compression Type 2 : 425.42 MB/s
Encryption Type 1 : 98.05 MB/s
Encryption Type 1 : 729.24 MB/s
DirectShow Encoding : 5.10 s
Memory Performance
Bandwidth : 6,389.60 MB/s
Graphics Performance
Memory Bandwidth : 59,897.20 MB/s
Video Decode : 0.71 s
Alpha FSP : 591.46 F/s
ALU FPS : 869.95 F/s
Texture FPS : 907.39 F/s
Hard Disc Performance
Avg Throughput : 47.82 MB/s
Vnix
Well after fresh install I can do that... I can adjust the clock I want but after few updates it's out of control..... There's sometime... it will drop to 2d mode but very rare...
alcoholbob
6,380
448
Enjoy Windows 7 then, since I switched from Vista 64 bit all I run is full 3D mode 24/7 lol the only possibility is to manually underclock when Im not gaming.
toyota
12,957
the last 2 sets of drivers have been screwing downclocking up. on a fresh boot it works but after some games or apps it will refuse to downclock anymore. I hate using 30 more watts and running higher temps for no reason other than Nvidia cant get their shit straight.
chizow
9,537
Are you running multiple monitors? The GPU throttling doesn't work when multi-monitor is enabled.
Vnix
Only one 21.5" LCD monitor.
