I have a cooling problem with my PAL 8045. It only gets full CPU die contact when hot!. I get wild temp fluctuations until about 46 degress C. After that, all is fine, and it won't move past 47 C. for anything. The temps are checked by diode against the CPU, and one on the HS for comparison. They both show the fluctuations till around 47 C. The readings posted are from the bios, via SANDRA
I was wondering if just adding another tensioner washer to the springs would take up the slack, or does someone have a better way?
