PAL 6035 with Delta 7K and 5K. How much difference should I expect?
RoCo
As the title says, I wonder how significant cooling effect there can be from moving from Delta 5K onto 7K hair dryer?
Cooling 1@1,43GHx AXIA Y chip on MSI Turbo
I've read a lot of reviews and some indicate 7-10C difference, whereas others only 3-4C... Which is more correct?
Thanks
😕 I am taking this review with a pinch of salt and would generally prefer to hear from ppl who have a similar setup/experience. Anyone?
Thanks
I have a PAL 6035 with YS fan. I replaced it with the Delta that came with my FOP38. The readings indicate that Im getting about 3 degrees lower CPU temp with the Delta.
Personally...i'd trust an article on anandtech over someone else. At least we know for sure that the reviewer knew what he was doing...😉
Thanks, this is what I wanted to know. In fact, my PAL6035 came with a 4200 rpm., 19.42CFM Delta MP fan, which is not performing very well. I will be replacing it with YS Tech 26 CFM.
Where do you guys get these fans & heatsinks? Every online store I check has the same Taisol stuff and nothing else but OEM junk.
I have the GlobalWin WBK38 with DELTA and it is LOUD and I hate it, despite it's incredible cooling abilities. I need a much quiter fan/hs combo.
I'd prefer to buy a HS with the fan already installed, as my carpel tunnel makes it difficult for me to perform such tasks. It's a bitch and I'd rather not go through the frustration.
I buy a lot of stuff from KDcomputers.com and they have great service, so what can I buy from them that will not be LOUD, but that will do a good job of cooling my AMD 1.2 T-bird? How about the Global Win WBK68? The fan is rated quieter than the Delta.
www.overclockers.com has a way to quiet the Delta using silicon and electrical tape and I wonder if that would quiet the Delta enough to satisfy me?
www.kdcomputers.com/cooling1.htm has a list of coolers available through them.
Opinions?
