Muse
The roof job is done, I've got the materials to fix the east wood wall (sill, 2x4 joists, OSB sheathing, Hardieboard, etc.) but having finally removed everything from the garage and swept out the roof-job debris, etc. I figure now's a good time to paint the ceiling. If I don't paint the ceiling, it looks crazy, a combination of the old grey painted rafters, unpainted plywood, new rafters, sistered rafters. Plus, with the east wall completely open now, there's good light inside which will making painting easier.
The floor is concrete, which is dirty and stained (I spent over an hour yesterday scraping off dried paint, dried gunk of unknown origin, etc.). I don't want paint droppings on the floor, so I suppose I'll tarp as I paint.
I was thinking roll and brush, but searching online I see that some people spray a job like this. I've never spray painted, but I have an apparently unused Wagner 120 Power Sprayer. I have a 5 gallon bucket of Zinnser oil based white primer and a partly filled (enough) of Kilz 2 water based white primer. I have some semi-glass acrylic white, I could top coat too, or maybe just a coat or two of Kilz 2 would do.
I figure first I want to cut off most of the exposed nails that the roofers left. Mostly misses when they were nailing down from above, and for that I figure my reciprocating saw, a hack saw or even hammering flat if cutting off is too much trouble.
I am sweeping off dirt with a broom, figure I should maybe wash at least some of the surfaces before applying primer.
I want to do this pretty quick because I need to finish the wall and another project before the rains come. The wall presents problems, so I want ample time to work that out.
Suggestions and guidance, appreciated before I tackle this.
