Spray paint on peice of cardboard. Wait an hour. Touch cardboard. If sticky, wait another hour and repeat. When cardboard is not sticky, pick up X-box.
When I painted my XBox, 1 hour per coat of paint. I did 3 coats of paint and 3 clearcoats. I'd recommend at least 4-5 clearcoats though. After your last clearcoat, let it dry overnight to be certain. Oh, and less is always better than more.
