Paint Shop Pro 9 - Open With Command
maddawg
Happy New Year All,
I just installed the new version of Paint Shop Pro 9 and fully updated it. I tried to open a .jpg by right clicking and then click "open with" PSP 9. I get the following error message:
Windows cannot find the specified file. Make sure you typed the name correctly and try again. To search for a file click start and then click search.
I had PSP 8 and it worked fine. Is anyone else having this issue and Is there any way to correct this?
Any help would be greatly appreciated!!!!!
Originally posted by: maddawg
Happy New Year All,
Go to the PSP website, limit your search (in the support section) to PSP and v9 only, and key in "open with" and "Windows cannot find the specified file" and you'll find the answer. There are some registry settings to correct.
http://support.corel.com/scripts/rightn...JnBfc29ydF9ieT1kZmx0JnBfcGFnZT0x&p_li=
