Originally posted by: SWScorch
dehydration, not enough potassium, wrong breathing pattern, bad form, a number of things actually. I usually get it when I'm not breathing properly or when I'm somehow constricting my lungs through my posture. Eat more bananas (they help with cramps) and try to run tall; with your head up and torso vertical and see if that helps. For what its worth, I used to get those all the time back in high school when I was in so-so shape. I haven't had one in years though, so maybe it's just due to being out of shape?
Originally posted by: nfamous
My fiance is an athletic trainer......and she says that the pain is caused by your body being out of shape & not being able to supply enough oxygen....the quickest way to relieve the pain is to hold your arms above your head....it improves the airflow and some other things that i can't remember...
You mean bloodflow, and do it while stopped? 😉 Running with your arms above your head would be rather hilarious to see.
Originally posted by: dmw16
What causes that pain in your side while running?
Is there any way to prevent it?
Originally posted by: ahurtt
Wow a lot of misinformation here. Runners cramp in the side typically has to do with lactic acid buildup and being out of shape.
explanation
explanation
yes a lot of misinformation, information
No, raising your arms over your head allows more air to enter your lungs and stretches out the ribcage, allowing your lungs to fill more fully. It's a common practice to rid side stitches. You've never seen people running with their hands on their head?
