Several months ago I was testing overclocks on my computer (1600xp+). By the time I was done I had it running nice and smoothly at 1950XP+ (1.63ghz). Unfortunately, I think I may have damaged somethign in the process, and my computer no longer has the ability to restart or shut down from Win2K. I can either do a hard reboot and/or manual shutdown.
That's not the issue, however. The problem is this. I keep on getting errors and problems in Win2kabout my paging file needing to be increased b/c too many problems occurr. (Right now it is set at 20mb). I right click on My computer go to, Properties, Advanced, Performance Options, Change. RIght now I set Initial Size at 192mb and maximum at 576mb. After I do a hard reboot/shutdown since I have no choice, the Volume Label changes the Paging file to what I set it to. BUT, the currently allocated paging size is labeled at 20mb!!! I have no idea how to change it. I thought it is b/c I can't shutdown/restart probably that my computer can't change the settings, but the Paging File DOES change, yet the allocated size remains at 20mb...so I'm at a loss. Please help.
Thanks ahead of time.
Edit - I have a 40gig harddrive, right now I only have 1.5 gigs free... but more than enough for the paging file.
