Paging 1900 XT/X (512) Owners
Capt Caveman
34,543
651
Originally posted by: akshayt
I wouldn't recommend antec smart power as none of them give more than 25A @ 25C, 300watts max power, atleast for the 500 watts.
also, you can't just add 12v1+ 12v2
Stop posting, since you don't know what you're talking about.
My S12-500 only has 17A and 16A 12v dual rails and runs my complete system overclocked(including X1900XTX) fine.
PianoMan
505
10
Antec TruePower 480W Blue
These cards draw some current - idle PSU fan speed went from 900/1250rpm idle/load with a 7800GT to 1250/1950(max)rpm idle/load with an X1900XT. Voltages are fine and stable, though.
Interesting a 350W PSU can handle it. Also interesting on Aspire also holding up the dutues as well. Anyone know who makes Aspire's PSUs? Or are they in-house built? Just curious while I was shopping for SFF cases, looked at the Q-Pack first (before getting a MicroFly [no PSU]), and everyone was saying to get rid of the Aspire 420W PSU before anything else.
PM
OVERKILL
2,103
I'm surprised, this turned into a pretty active topic.
Keep the replies coming guys. :thumbsup:
jiffylube1024
7,430
Originally posted by: BassBomb
There is a spec written below the dual 12V rails that you can read to see the combined amperes
^ He's right. You should look at the combined power on the +12V rails and make sure that it's above 30A or so.
I forgot to mention, the Enermax FMA II 535W, for example, is rated at 22A +12V1/22A +12V2 and combined +12V at 36A.
CP5670
5,535
613
Another 520 Powerstream user here. Although it's a lot more than needed, as the system uses about 230W on load.
dr150
6,570
24
I have a 400W Silenx PSU.
Is 18A on a 12V rail enough for these cards????............
sodcha0s
1,116
Originally posted by: OVERKILL
Originally posted by: josh6079
Damn, how much is it bent?
That's the risk in taking an OEM. I'm guessing it came sort of loose in a box with just the needed cords and drivers right? My old X1900XTX did when I got it from Sapphire OEM.
Yeah, everything was all loose, it was double wrapped in bubblewrap though.
It's bent a little bit, nothing crazy, but i'm not taking a chance since it was a $300 item.
I got the PowerColor 1900XTX not long after release and it was the same way. Didn't feel comfortable with that so I RMA'd and the next one was also bent. I've been running it ever since with no problems, kinda weird though.....
Elfear
7,126
738
The specs I've seen say the X1900XTX uses ~10A at stock clocks. Start overclocking and raising voltages and you're probably looking at 12-15A. That's very little left over for the rest of your system. I'd say 18A is way too little, especially if you have an oced cpu and more than just a DVD burner and one 80mm fan.
Avalon
7,567
156
Probably not, just to be safe. I used to have a 420w Enlight with 18A @ 12V on a highly overclocked Sempron system, and had to reduce my overclocks when I added a Geforce 6800 to my system to keep the same level of stability.
Of course, you may not be overclocked, but I'm just trying to lay down a safe limit.
BassBomb
8,390
THANK YOU SIR JIFFSTER!
JBT
12,094
My PowerColor was the same way I heard of a few manufacterers having that issue. I took the HSF off and the bend went away so it was something with the stock HSF. Its not there at all with my Accelero X2.
KingGheedora
3,248
Jesus Christ when will you stop posting?
Firstly; I never mentioned SmartPower, so now you've made yourself look like a dumbass through assuming I will inform you that his PSU is a TruePower. Secondly; As for "just adding" the rails, I'm not that retarded, but I couldn't be arsed working out and deducing ~30% from an arbitrary figure.
The fact is the X1900XT 512MB runs perfectly fine on these identical rigs with the CPU OCed to 3GHz and the X1900XT 512MB OCed above XT-X clocks. Christ, moron, your posts are painful to read as it is and can usually be ignored, don't make me read anything you write by directly replying to me ever again.
Man, that guy gets totally abused every time he posts.
Jules
Is a x1900xt alright on a ENERMAX LIBERTY 400W with 30 Amps on the dual 12 rails?
jiffylube1024
7,430
Yes. Enermax doesn't BS around when they rate a product - 400W is definitely safe up to 400W loads and they often go higher.
For example the Liberty 500W tested to be functional up to ~535W.
OCZ is usually very good for their ratings too, because OCZ uses sustained wattage, not peak to measure.
400W+ Enermax/OCZ you should be fine. 450W+ Antec, you should be fine.
dr150
6,570
24
Fry's Currently has an Ultra X-Finity 600W Flex Force PSU for $30 after rebate this weekend.
QUESTIONS:
1.)Will this work on an 1900XTX/1950XTX... along case full of stuff (5 HDs, etc)?
2.) How is the quality of this Ultra brand?
Product Summary:
Breakthrough technology! Phenomenal power distribution. Easy to manage cabling system! Extraordinary airflow! This sizzling new X-Finity power supply features the innovative new dual rail technology for better power distribution. You'll get the smooth, trouble-free performance that's perfect for your powerful gaming system. The FlexForces' incomparable cables are dressed in a great looking titanium finish. Specially engineered cable design promotes easy cable management and 30% better airflow than ordinary cables by easily routing cable under the motherboard, behind drive bays... anywhere that gets typically unsightly power supply cables out of the way of airflow. Crafted to accommodate both AMD and Intel CPUs! Versatile. Dependable. Affordable. The X-Finity FlexForce ATX power supply.
Compatibility
AMD
Intel P4
UPC 022769318479
Manufacturer Part Number ULT31847
Product Type ATX 12V v2.2 & EPS 12V
Current 10A @ 115V AC - Input Current
Current 6A @ 230V AC - Input Current
Current 30A @ 5V DC - Output Current
Current 25A @ 3.3V DC - Output Current
Current 18A @ 12V DC - Output Current
Current 20A @ 12V DC - Output Current
Current 0.6A @ -12V DC - Output Current
Current 2.5A @ 5V DC - StandbyOutput Current
Manufacturer ULTRA Products
Product Name X-Finity 600W ATX12V AC Power Supply
Output Power 600 W Maximum
Output Voltage 5V DC
Output Voltage 3.3V DC
Output Voltage 12V DC
Output Voltage -12V DC
Output Voltage 5V DC Standby
Input Voltage 115V AC
Input Voltage 230V AC
Output Power 600W
Brand Name ULTRA
