After upgrading my mobo and CPU, I repaired my XP Pro installation from the XP CDROM. Everything seemed to work well, except that at one point, I started getting the message, "Your system has no paging file, or it is too small," every time that it boots into Windows. When I go into Control Panel to fix the problem, it shows the custom set 1024 MB pagefile that I put there, but it also shows 0 MB currently allocated. I've tried changing it, putting it onto another partition, putting it onto another hard drive, letting the system manage the pagefile, etc., but I still get the message at boot and show 0 MB allocated. So far the setup seems to work without any other problems. Windows says it is assigning a temporary pagefile, and pagefile activity is displayed in various places.
Any ideas of how I can fix this without a clean install would be appreciated. Thanks.
