I have a computer that has a small hd, and only 256 ram. I use it only for burning cd's and Dvd's, but I used to use it for everything, so it is filled up with junk and started to crash on me.
I bought a larger HD, and I want to load windows on the new hard drive. Then copy over to the new hard drive the info I want to keep, and reformat and repartition the new hard drive.
I would like to partition the old HD into 2, with one section being used as a partion only for the swap file. I want that partition to be the first partition.
Currently, Windows is working on the old drive, the new drive is installed and recognized by the bios, but not formatted.
Just trying to get the order of what I need to do figured out.
If I boot from the WinXp disk, and let it format and install itself onto the new HD, I can then copy over info to the new HD.
I can then manually format the old HD. How do you make a partition the first partition?
I would then change the swap file location to the new partition.
Can that partition be hidden?
Currently, the old HD is drive C, and D and E are the optic drives. How do I make it so the new HD will be drive C, the unhidden partion be drive D, the optics can be drive E and F, and can I make the swap drive hidden or another letter, like S?
Would it be easier to change letters before installing new OS and HD?
Any help or comments on any issues above would be appreciated.
