Packaging a full system for shipment.
mattjbak
909
Would the case box be sufficient? It's a lian li v1200 plus, the internals would remain installed. If not what else should I do?
Thanks!
Apr 17, 2003
37,622
the box is fine but i recommend using fedex. I personally would at the very least remove the HSF and prolly the video card for the matter. Those so heavy component that can easily snap off during transportation. The LL v1200 is secure enough for the hard drives, i wouldn't worry about it.
SarcasticDwarf
9,574
To ensure that nothing gets broken, remove the HSF and any expansion cards. The HSF should be removed because of weight. Remove ALL expansion cards (video/whatnot) because if the case is damaged (bent, twisted), the cards will survive.
