Pacific Assault help
Jumpem
10,757
I've just started playing it, and am where the Japs attack Pearl Harbor.
When you have to go into the battleship to keep it from sinking what exactly do you have to do? I keep dying when the 60 second limit is up. :(
warcrow
11,078
11
...you dont go into it, to prevent it from sinking, you go in to save some soldiers. Its pretty liniar...where are you stuck? Take a screenshot, ok?
(Its probably some ladder you're missing or something. Is it where there is a room on fire, and they're trying to open the door, buts its stuck? If so, there is a highly preassurized gas tank you have to shoot the top off of.
Jumpem
10,757
Right after I get off of a PT boat and go inside. I have no idea what to do. I've found some valves I can turn to shut off steam.
warcrow
11,078
11
Once you turn those valves the fire dies down. I guess I'm not understanding why you're stuck. Take some screenshots.
Jumpem
10,757
If i'm still stuck tomorrow I will. I should be getting to bed so I can get up for an interview in the morning.
BFG10K
22,709
3,007
There are basically a bunch of glowing red valves you have to turn to counter-flood the ship to stop it from keeling over. Just keep turning them and follow the pathways as the steam stops flowing.
dbzwukan
532
What he said.
I'm now bored..... all the islands look the same.
Jumpem
10,757
Is the entire game heavily scripted? I'm on the first island after Pearl Harbor. So far the entire games has been "do this.. now do this". It feels like I'm not really in control. It's basically not any fun to play. :(
