P8Z77 V Pro questions
1badnighttrain
This is my first build in a decade and have hit a couple of bumps.
build
v-pro
3770k
2 Corsair Dominator Ram sticks 32
intel 520 240g ssd c drive
cooler master 212 evo with 2 Logisys fans running push/pull
Fractal Design case
bios 1708
fired it up at this point and hit the seemingly common fan speed wall. I discovered that the only fan that would get me past this stop was the factory intel fan for the 3770k. Once past I swapped wires around and shut down the cpu fan monitoring.
I see in some of the forum posts that I should be able to adjust the low speed rpm limit. I have not been able to find this setting, just off or on.
Where is it? Do I need a bios update?
Should I be updating the bios anyway. From what I have read there are some problems with some of these also.
I added a 1TB WD Caviar Black drive. The system does not find this drive. I figure I am overlooking a jumper or perhaps I am plugged in to the wrong port on the board. I have it set on SATA 6
I have other hardware to plug in to this but need to get past this hard drive install first.
thanks for the help
Steve
Regarding the 1TB HDD, which SATA6 port is it plugged into? If it's one of the Marvell ports (dark blue I think) then it won't be recognized by the BIOS right away. Plug it into one of the Intel ports, either SATA3 or 6 (data rate doesn't matter on non-SSD drives) and it should find it right away. The marvell ports have to be initialized, and the OS needs a driver to see them. Avoid Marvell for your boot drive.
