P8Z77-V Pro LAN upload speeds poor
fng01
68
I am seeing an upload speed of just .40Mbps using the onboard RJ45 LAN connector. My download speeds are correct for my provider at 30Mbps.
When I install an old network card my speed returns to 11Mbps for upload and remain the same for download.
My concern is that I have already returned my first P8Z77-V Pro becasue of an onboard sound failure and this same problem.
So, I did contact tech support and they suggested that I turn of the iControl feature which I did with no results. I am waiting on a reply back from them but in the mean time thought I would share this with all of you.
I am hoping that this is really just a simple setting that I have overlooked.
Has anyone else heard of these boards having this problem? Just seems funny that I would have gotten two in a row with the same problem.
fng01
68
Second board going back to Amazon. Getting dissapointed with Asus. I was a big fan.
smangular
347
Your decision but perhaps you should do some more extensive testing first.
How about simplifying testing using LAN to LAN, upload and download? What OS? Which drivers?
